Deaver/eibach combo ?
zx14teryx
Has anybody found a dealer in so.cal or AZ. That knows how to do ride height recalibration?
I can tell you Bradley Ford in Lake Havasu does not know how
RaptorVette
Corpus Christi, TX
I understand that the ride height needs to be set on live valve (19-20) raptors and I understand how this affects the performance of those raptors. I also understand that a ride height calibration is not necessary for the 17-18 Gen 2's. Is there any ride height or other calibration that SHOULD be done on the earlier Gen 2's to ensure all of the electronics function correctly?
I'm relatively new to this and looking at putting the Eibach/Deaver setup on my 2018.
You won't have to worry about the calibration with your shocks.
TrewRaptor
Tucson AZ
I have had the Eibach for 2 weeks and installed the 3+ Deaver's today. The front has been great but until today the rear was still hopping. Post Deaver the truck feels much more stable and planted. Only city driven so far but I have a drive up to Phoenix tomorrow and will be able to provide some highway behavior. Along with the front I had the camber bolts replaced and an alignment that was better than stock (surprisingly).
K223
Florida
Any profile shots of the stance?
TrewRaptor
Tucson AZ
I'll take some today and post. Doesn't seem like much of a difference but the wife mentioned it seemed higher when she got into it last night. Which is an unbiased comment because she wasn't aware of the lift being added. I'll also post the alignment specs.
zx14teryx
Year?
zx14teryx
Ok.. I brought the ford dealer notes from this thread on how to recalibrate ride height. Can someone in the know look at the readout I asked for and tell me if they did it correctly? Feels maybe. Bit softer up front.
K223
Florida
Pretty blurry. Can you post a different view of just the simple measurements? I think it looks pretty good though.
TravisHTX
Houston
Looks like -.03 inches on the front. They did it right, you are good to go.
K223
Florida
Oops that’s a print out. But yea I agree after looking again. You are recalibrated. You would be around 30mm give or take in the front if you weren’t. Good to go!
