Deaver +3 with drop shackle
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by mattyz99, Apr 1, 2020.
  1. mattyz99
    mattyz99 Full Access Member
    60
    10
    Dec 10, 2016
    Hi all, I’m looking to finally pull the trigger on a set of deavers, I want to keep the stock ride height so I can do +2, or +3 with a drop shackle, I assume you get more droop with the new shackle, anyone running this setup, I would like to hear pros of one over the other also did you need to install limit straps with the +3 and shackle so you don’t max out your rear shocks with the extra droop?
  2. Dustan
    Dustan FRF Supporting Member Supporting Member
    189
    173
    Dec 10, 2018
    Boulder Colorado
    I have +3 deavers with +2 rpg shackles and SVC bumpstops. I was running rpg 1.5” collars up front and with that setup I had a 1” rake in the front. I just went fox 3.0’s and for some reason they raised the rear a 1/2” but now I have the ability to put the front at whatever height I want so I’m at a 1/2” rake at the moment. I don’t think I’ve been in a full droop situation yet but I like the fact that if I want 1” in the rear I can just put the stock shackles in. That’s why I went this route. This is on a 2018
  3. CHMP
    CHMP Full Access Member
    134
    61
    May 28, 2019
    Santa Cruz
    What will deavers noticably do for spirited on-road driving? I swapped to Eibach springs up front a week ago and it literally made everything about the truck better. Would love to start targeting another big time improvement mod this summer.
    element217 likes this.
  4. mattyz99
    60
    10
    Dec 10, 2016
    Basically I’m asking if there’s any difference besides more droop on doing deaver +3 with lowering shackle vs deaver +2, and those that went with +3 did you also have to install limit straps
  5. Wfo
    Wfo FRF Addict
    1,651
    1,135
    Sep 22, 2013
    Syracuse
    Limit straps aren’t needed. I have Deaver +3 with rpg drop shackles.
  6. Bowewelding
    Bowewelding Full Access Member
    99
    14
    Aug 13, 2017
    The amount of droop travel is going to be the same as stock if not less..it is depicted by the length of the shock.. the shock is connected to the frame and will extend the same as it did before.. you may get more bump travel out of that setup.. the +3 is a stiffer pack to compensate for bed racks and gear..if your gonna run minimal gear and want a stock height just get the +2 pack, I have them and it significantly helps plant the rear end to the ground..the only thing left to do is put a urethane bushing in the stock shackle to promote better movement..the stock rubber one kinda sucks in my eye
  7. mattyz99
    60
    10
    Dec 10, 2016
    Copy thanks
  8. Dustan
    189
    173
    Dec 10, 2018
    Boulder Colorado
    Got long winded on my post. My main reason for +3 and shackles was to have options. It was my first suspension mod and I hadn’t decided what my plans were. I just wanted the rear end to calm down. Deavers are one of my top mods.
    Wfo likes this.
  9. Bowewelding
    99
    14
    Aug 13, 2017
    Yeah I did the eibach coils first then the deavers..the leaf pack helps a lot..I wish the shocks were more tunable. last night got the king oem replacements. Gonna put them on asap then save up for the rear ones
  10. Bowewelding
    99
    14
    Aug 13, 2017
    The fox shocks rebounded way to fast for my liking.. tried to slow it down but foxes design of the bleed holes leaves no option
Share This Page
