Deaver +2 or Deaver +3 with Shackle?
BlueSCrew19
NorCal
I'm planning my first suspension upgrades for my '19 SCrew, and I've been reading everything I could find here on the forums. I have two goals with this upgrade: I want to "fix" the rear suspension, which feels unsettled on-road and I also want to get some hands-on experience with the Raptor suspension (since I'm sure I'll need it for repairs once I start really off-roading it).
I'm trying to decide between these two options:
  1. Deaver +2 with RPG bump-stops.
  2. Deaver +3 with a drop shackle and RPG bump-stops.
I want to keep the height the same, since I'm not currently planning to do anything to the front of the truck (next project!). Will the second option (Deaver +3 and shackle) feel the same as the first option, but give me more options later? Or is there a notable difference in the "feel" of these options that I should be considering? I've read that people are using option #2, but I haven't been able to find any comparisons between these options in the previous forum posts.
Anything else I should be considering for a first suspension upgrade?
Thank you!
OffroadAlliance.com
Boston, MA
Here is one of our shop trucks with Deaver +3 with RPG bump kit and RPG drop shackles. Rides great! Tons of suspension articulation. Would definitely recommend. Let us know if we can get you a quote on anything.
adllewis42
Seattle
I wish I could be more help but this is all so new and confusing to me. What are the differences between +2 and +3? And why do you need a drop shackle? The shackle is the part that connects the rear of the spring to the truck, right? All I want to run is a cap, fridge, rooftop tent, and some other camping equipment without having the rear squat too much. Maybe you're in the same boat?
WHYUMAD
New Orleans, LA
Following... as I’m considering +3s with stock height shackles or +4s with a drop shackle. (Want to put 37’s on)
MnFlyer
MN
Are the front springs stock or after market?
Any other considerations for going with +3 and a drop shackle, is brake lines?
BlueSCrew19
BlueSCrew19
NorCal
The truck is completely stock right now (minus some superficial stuff like Line-X and a Tonneau).
What would I need to consider for the brake lines? Do I need longer and/or tougher lines, or just a new place to route them?
BlueSCrew19
BlueSCrew19
NorCal
I'm also really new at this! The Deaver's get rid of the factory block, which is a 2" block that sits between the bottom of your factory leaf springs and the top of your axle. That means a +2" Deaver spring will make the truck exactly the same height as a stock truck (minus the 2" block, plus 2" from the Deaver). Similarly, a +3 will bring you 1" over the stock height, for the same reason. The shackle is the part that connects the rear of the spring to the truck, and I'm considering a 2" long shackle (stock is 1", to my understanding), so that in combination with the +3 Deaver springs the truck will sit at stock height, rather than 1" over. That is what I have gleaned from watching YouTube videos and reading this forum, and you can blame me for any wild misunderstandings here :)
Dustan
Boulder Colorado
Not much of a help yet, but I have +3 deavers with the rpg drop shackles and a svt bump stop kit on the way and will be installing as soon as possible. I’m running 1.5 spacers up front. I think you’re on the right track and off-road alliance beat the other prices I was quoted. Lots of information to dig through on here.
