GEN 2 Cylinder Number Assignments
CigarPundit
On the road to serfdom...
Georgia
I just had the plugs changed and I’m now getting a misfire. DTCs are PO316 (misfire on startup) and PO306 (misfire on cylinder 6). I’d like to just check to see that the coil is properly seated as a first step. Can anyone tell me which cylinder is number 6? I did some searching around but so far I haven’t found the answer. I’m probably not searching for it correctly because I’m sure the info is out there. Thanks.
CigarPundit
CigarPundit
Georgia
To follow up on this, I have found some information stating that all Ford 6 cylinder engines follow the same cylinder assignment protocol. From front to back, passenger side is 1-2-3, and driver’s side is 4-5-6. So number 6 would be driver’s side and farthest to the rear.
If anyone can confirm this, I would appreciate it.
CigarPundit
CigarPundit
Georgia
Thanks! Same result. As long as I’m in there, I’m going to pull the plug and check the gap. Since it is only happening on one cylinder, maybe that one is gapped a little too close?
New Nick at JDM
New Jersey
Thanks! Different than what I found, but same result. As long as I’m in there, I’m going to pull the plug and check the gap. Since it is only happening on one cylinder, maybe that one is gapped a little too close?
You're welcome!
The plug being off could be the case!
