CV half shaft replacement
BGA23
Scottsdale, AZ
One of my CV boots is torn apart and I figure that since I need to remove the axle to replace the boot I may as well just replace the entire thing, not just put on a new boot.
In order to remove the axle, do I need to unbolt things like caliper, tie rod and coilover in order to get it out? Or once the axle is unbolted I can shimmy it out and work the new one back in?
CarmanKyle
Pasco, WA
Dive in and find out.
You'll need to pull the UCA nut, and tie rod nut and knock them from the knuckle, and move the knuckle out of the way. It'll make it easier to remove 2 bolts from the caliper to pull the caliper and rotor. Remove nut under cap on hub, wiggle end of axle from hub, then yank on the axle and it will come out.
I have replaced just the boot, boot came from NAPA with grease and new clamps. Unless the CV is damaged, I wouldn't replace the whole thing unless you want to keep the old one as a spare.
Members online
93,145
56,419
TwistAir
Latest posts
