Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
Custom Tailgate Emblem KickAssery
Discussion in 'The Double AA' started by TheDoubleAA, Feb 18, 2015.
  1. TheDoubleAA
    TheDoubleAA Full Access Member
    38
    515
    191
    Oct 21, 2012
    Kemah Texas
    Alot of folks have been asking about this and we've finally perfected it enough to make it a kit. It can wired up as a running light or as a brake light depending on how you want to do it. It's as simple as popping off your old one and putting this one in place and wiring up to either brake or running lights. Drink a beer , smoke a cigar and enjoy.
    You can have anything you want on it to say or image and in just about any color you want. I recommend a legal color ie RED but thats just me.
    Where to buy? Click here: Raptor Custom Lighted Replacement Rear Emblem for 2009 - 2014 - $149.00 : The Double AA, Corvette and Camaro Modification Products
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    AbnMP13 and gbrown27 like this.
  2. AbnMP13
    AbnMP13 Full Access Member
    884
    458
    Nov 9, 2014
    Mississippi
    How does that affect the camera?
  3. TheDoubleAA
    38
    515
    191
    Oct 21, 2012
    Kemah Texas
    as long as the camera is clean then it's good, If it has alot of moisture or lets say during rainy times then it does have a bit of a red glow at the top. Fix, keep your camera clean.
  4. AbnMP13
    884
    458
    Nov 9, 2014
    Mississippi
    Was just wondering if it would work with the camera.
  5. TheDoubleAA
    38
    515
    191
    Oct 21, 2012
    Kemah Texas
    absolutely
  6. farman
    farman Full Access Member
    257
    145
    Jun 13, 2012
    Upstate NY
    Cool, I might just need to order me one of these since my license plate is XTINCT as well. How hard is the install.
  7. TheWolf
    TheWolf Full Access Member
    46
    967
    1,347
    Nov 15, 2013
    Spokane, Washington
    Can you post a pic of the red Ford one, but not lit up?
    Is the plastic actually red or are the LEDs red and the plastic is clear?
  8. TheDoubleAA
    38
    515
    191
    Oct 21, 2012
    Kemah Texas
    pretty easy actually. Just pop off the old emblem and take off the cover if you have one on the back of the bed with torques. Run your wire through the bottom and out one of the holes and run to either running light or license plate light. Tap your power and ground. Remove the 3m tape from back of emblem and set in place. Remember that you need to use pressure and heat for it to hold. (If you have a camera use gentle force or you can buckle the plastic on the OEM piece.) once in place you're done. You can either run power to the brake lights or running lights. I ran mine to the running lights.
    ---------- Post added at 12:08 PM ---------- Previous post was at 12:07 PM ----------
    it's actually clear white until illuminated. Once illuminated it is what ever color you chose.
  9. AbnMP13
    884
    458
    Nov 9, 2014
    Mississippi
    Are they all white until illuminated?
  10. TheDoubleAA
    38
    515
    191
    Oct 21, 2012
    Kemah Texas
    yes
Share This Page
