Crank case pressure sensor engine loom
Donovan
DC
Hello!
So when I was doing spark plugs, I accidentally pull the pins out the back of the connector that goes to the crank case pressure sensor . I think it’s the crank case, because that is a code that I have. See photo attached
All three pins came out. And I tried to put them back in, no dice, check engine light.
I cannot find the connector that goes into the sensor so I can cut and splice it into the wire loom.
so whatever this guy was talking about at six minutes and 20 seconds….When I lifted that up I pull depends right out of the back of that sensor..
I can’t find the **** on schematics can somebody tell me the damn part number please
CobraJay
Tweaker by trade
NE Ohio
Are the pins still attached to the wires??? If so try individually plugging them in without the housing, pins only on one side and connector on other. This should get you going for now.
As for the connector look for any identifying numbers/letters and post them up. This can help you to find the replacement connector and pins.
Donovan
DC
So I tried putting the pins back in before anything else..
I don’t think they were all the way seated. I just have to get a new wire loom connector..
CobraJay
Tweaker by trade
NE Ohio
Dont try to use the connector they were pulled out of, just grab the pins and plug them into the good connector that was undamaged.
Donovan
DC
Ok.
ported the pins directly into the sensor.
fingers crossed it works.
Donovan
DC
All good! I put the pins directly into the connector and I’m good to go for now
