Hi Everyone.
Thought I would ask yall about the correct Oil Level Check process is as I am getting 2 diffrent readings. I am trying to understand what the correct process is as I have been diagnosed by the dealer for Oil Consunption issues.
Process #1- Run the Truck till operating temperature (150-200 Degrees Oil Temp after driving), turn off the truck on a level surface. I then wait 15min to let the truck cool down and then pull the dipstick and get this reading below (Right at the halfway mark)
The truck has had 1500 miles since the last oil change, and so it looks like it burned half a quart so far. Normal?
Process #2 - Run the Truck till operating temperature (150-200 Degrees Oil Temp after driving), turn off the truck on a level surface. I then wait more than 15min ( like 1 hour or so) since I was told by the dealer to let the truck sit for a while for ALL of the oil to drain down and get this reading below (Right at 3/4th and under the Max line on the dipstick)
Which is the right process and reading. I am confused on how the dealer says to wait way longer than what the Ford Manual says(15min). Not sure what the right process is.
Sent from my SM-N950U using Tapatalk
