CONNECTOR PORT ABOVE OBC PORT under GEN 2 STERING WHEEL
blademan
Hello i was opening up the plastic area under my stiring wheel above the OBC port and found this RJ11 type connector.. ANyone know what is this for??
THanks
Antho
My guess would be it went to that big a$$ hole in your dash. Where does the other end go? My valentine 1 gen1 radar detector had a concealed face that used the same connector. My guess would be it used to go to a radar detector with a remote/concealed face That someone decided to mount in that hole.
blademan
blademan
haha! Damit man.. I will have to trace it back.. did not even think about that...lol.. maybe we are on to something. i will report back
blademan
blademan
OKAY-- Thanks for you push to get me to investigate. I was surprised everything JUST POPS OFF like a cheap ole truck.. MY USE 65k truck make me realize FORD probably has a 300% profit margin.. LOL.. I was surpised everything it just plastic and pops off, then punch it back in place..lol. anyhow.. I traced the cable along with a BLACK AND RED cable.. all 3 ran together in a zip tie under the DRIVER SIDE FORD PERFORMANCE STEP area, then i followed it to the DRIVERS SIDE PASSANGER seat area where it came out the the RIBBON CABLE went to a MONO SUB WOOFER AMP model 1000.1 KICKER AMP-- it was plug into a port called " REMOTE BASS" whatever the hell that is.. maybe a BASS KNOB? LOL.. Maybe he has some audio controls in that area -- but that dont make sense- Why would he REMOVE whatever was in that HOLE!! and left the big nasty hole in this 100k custom truck.. I doubt he was pinching pennys- i mean he traded it in for a 147k BMW SUV from what i was told at the BMW dealership i bought the truck from.. NOW A RADAR detector would MAKE SENSE!! HE LEFT THE FOLLOWING ITEMS WITH THE TRUCK when he trade it in..
1. COBB CONTROLER
2. COBB RADIATOR- of course this is a fixed gear, but some guys take em out before trading)
3. A FULL SIZE FUEL RIM and 37" tire with A FULL SIZE BRANDNEW JACK(yes spare was stil under truck
4. ALL TYPES OF SECUREMENT GEAR inthe truck bed from BUILT RIGHT INDUSTRIES- atleast 500$ work of those gadgets...
5. ALL WEATHERTECH MATS like new..
6.ZION WINCH AND REMOTE CONTROLLER.... -- priced with bracket at 3k plus...
7. MINT ROLLING TOPPER brand cannot rememmber but google it at 1600
So i believe it had to be a RADAR detector of some sort and that RJ11 cable was clearly connected to the AMP so .. oh well i got a BIG OLE hole that i am about to INSTALL SOME DUMMY SWITCHES that look cool.. i hope i dont f#ck the cutting up.. i gotta trim some of that plastic
EastEndAngler
Long Island, NY
@blademan - that actually looks like an RJ45 (think ethernet /CAT6) and it looks like its running all 4 pairs (8 wires total). The V1's i'm pretty sure run off an RJ11 , so you could rule out that.
Faster48
SE, Pa
That is an rj45 not rj11 but would most likely have been for a remote sub adjustment knob mounted in that hole
blademan
blademan
1000 watt mono amp, bonus? or not?????
Yes- it came with a FUL customer system ,, 2 KICKER SUBS in a metal FORD box under seat , then 2 amps one is a 1000.1 KICKER , anothe is KICKER 500.4, some little crossovers , a TV something box so it can speak to headunit.. sounds really good.. Came in the truck
blademan
blademan
THanks brother!! I been looking into these switches by KICKER and does not look like it would work with this hole, but maybe?? customer switch?? Weird to cut a hole just to put this BARREL REMOTE SUB switch in.. i guess all it does is created LOUDER BASS sound?? never used one. but AGAIN THIS CABLE was laying right below the hole makes sense if it was
