The problem I am having happens once the in cab temp comes up to the set level, When I have the controls set to single or dual temp, and automatic. Once its up to temp the drivers side goes to full(LAVA) heat, and the passenger side goes to exterior flow through temp. The outside temp has been between -35f and 0f since this started about a week ago.
It started after a problem with the heater. If I remote start the truck when its -30 the heater will not blow heat.....ever. Not until the truck is shut off, key pulled, door opened, closed and truck restarted. Any ideas? I'm thinking its a relay for the last problem listed, but the first prob I have no clue.
