Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
Check out our Gen 2 Raptor Build!!!
Discussion in 'Custom Truck Shop' started by customtruckshop, May 14, 2018.
  1. customtruckshop
    customtruckshop LGE-CTS Motorsports Supporting Vendor Supporting Member
    934
    252
    Mar 12, 2012
    San Dimas, CA
    One of our recent builds for a customer, here is what we did so far:
    Custom "In House" build Front and rear bumpers
    Custom "in House" build bed cage and spare tire mount
    Rigid Light bars, pods, chase lights
    Fox 3.0 Finned Resi bypass F&R shocks
    Camburg Upper Uniball Arms
    BFG KR2 37x12.50R17 Tires
    Method Beadlock wheels
    Borla Exhaust
    We are currently adding a Whipple Performance intercooler and tune kit
    [​IMG]
    [​IMG]
    [​IMG]
    If you need anything for your Raptor or have any questions on the build give us a call!
    (909) 599-2228
    Ask for John or Dale
  2. falker79
    falker79 Member
    14
    9
    May 14, 2018
    Do you know how to adjust the front and rear adjustments to those shocks ?
  3. customtruckshop
    934
    252
    Mar 12, 2012
    San Dimas, CA
    If you are referring to ride height adjustment we can bring the front coilovers up about a inch.
    As far as compression, rebound and other shock valving and tuning these shocks do have a optional Dual Speed Compression knob, in their own words: "Add remarkable versatility and precise tuning with new DSC. A simple twist of either two adjuster knobs allows 10 separate low-speed and 12 high-speed compression levels. Included new black anodized aluminum reservoir increases cooling efficiency."
    We have other access to fine tuning the shocks as well.
    Hope this helps, Thanks
  4. DEGBTI
    DEGBTI Full Access Member
    53
    163
    62
    Feb 21, 2018
    couple questions, how much more did you have to preload the front springs than what they are pre-set at from fox to clear 37's"? I just installed a set of fox front shocks and it leveled my truck, but not sure I can run 37" off road. Did you make any other mods for clearance? Also, Can you please PM me a price on those tires?
    thank you!
    oh, and how did the tire balance? are you able to drive on pavement without vibration?
  5. customtruckshop
    934
    252
    Mar 12, 2012
    San Dimas, CA
    Our customer beats his truck pretty hard so we did not adjust the preload out of the box, however we did have to do a body mod by cutting back and welding in a smaller plate at the body mount which we do for $900.00.
    I will PM you the price on the tires.
    As far as the tires they did balance out ok and drive fairly smooth on the street but they do wear very fast on the street.
    Hope this helped, thanks.
  6. DEGBTI
    53
    163
    62
    Feb 21, 2018
    got the pm, thank you! Ill keep in mind the body mount idea too
Share This Page
