Carrying two kayaks
ZBoater
My lease ran out on my wife's MB R350 and we traded for a sedan. My Raptor is now responsible for cargo duty, which includes the kayaks. I had the MB roof rack and Thule kayak holders. The Thule holders will work on any roof rack. So I need a roof rack.
I don't like the racks that clamp on the sides. I don't like compressing the weather striping. My MB racks fitted into slots that were built into the roof. I didn't see any such factory option on my roof.
Right now the Thule Xsporter seems like my best option. Any kayakers out there that can share their secrets? I have two 12.5" kayaks that weigh about 60lbs each.
Rickoo
Massachusetts
I have a 17' sea kayak and have looked for a transportation solution as well. The Xsporter was a serious option due to the adjust-ability. I wondered how much I would use it in a lowered position. The Tracrac ONE is a lot cheaper. (can find one for $299 if you look) It seams almost the same except for the adjust-ability. I bought one and it's still in the box while I'm trying to decide whether to keep it or not. To use it, I'll have to take the tonneau cover off, clamp to the side rails and then remove it all when done.
I wish there was a better option.
TheWolf
Spokane, Washington
I had the Thule Xsporter on my last truck and liked it. Only downside is that it can't be installed with a bed cover, like most of those racks on your list. My Xsporter was the older version that had only two height settings and it ended up with scratches when I would move it up and down. Hopefully they fixed that on the new version. If I had to pick from your list I would go with the TracONE, unless you need the height adjustments of the Xsporter but it is twice the cost. If you think you may add a bed cover, go with the TracRac G2, which mounts on rails that sit on top of the bed rail. These can be used with covers that don't cover up the stake pockets, like the Roll-X or some of the other Bak covers.
ZBoater
ZBoater
So I've been doing some more digging. Bakflip has some nice options with the TracRac solution, which seems like the nicest one. That rail system is cool, and it allows for the bed cover also. But it's expensive.
Now I see this.
Erickson Big Bed Load Extender for 2" Hitches Erickson Hitch Cargo Carrier EM07600
Less than $200. Could it be that simple?
---------- Post added at 07:21 PM ---------- Previous post was at 07:19 PM ----------
And this one for $90!
Amazon.com: HitchRack Adjustable Truck Bed Load Extender: Rage Powersport Products: Automotive
---------- Post added at 07:42 PM ---------- Previous post was at 07:21 PM ----------
Ok, let me throw another monkey wrench into this.
The kayaks are super light, 39 pounds each. But 12.5" long and 28" wide. The bed of the Raptor is 50" wide between the wheel wells, and most of these extenders are 48" wide. The kayaks are angled so they'll probably fit on the extender but not in the bed. They'll have to be kinda at an angle. And I don't want to damage them. I already have the Thule carriers that attach to a rack. But dang those racks are expensive. I need ideas.
ZBoater
ZBoater
Ok, I think I found my solution. Yes, the commercial sold me. Not ashamed to admit it.
ZBoater
ZBoater
I assume you have to tie a flag off the end when driving with them?
Not sure. Good question. The carrier has reflective red tape at the end, but I don't know if that would satisfy any legal requirements.
infinitereality
SLC IR/8
Louisiana
Would getting a BlackFlip bed cover be another option and just load the yak up in the bed? Mine and another guy were carrying 2 yaks (3 of the 4 were 12.5ft) and just used ratchet straps. We hauled a couple ice chest, fishing gear, etc. We drove 4hrs, he drove around 8hrs.
ZBoater
ZBoater
I'm not sure. That would leave more than half the kayak dangling off the bed. I guess I could tie them down tight, but for $100 I think I'd rather support them on both ends. I don't think my kayaks would react well to being tied too tight. They're uber light and might flex or I might damage them. I just didn't want to spend $1000 on a rack I'll use twice a year.
Ruger
Northern Nevada
ZB, I'm no kayaker and I didn't sleep at a Holiday Inn Express last night, but with an arm that long sticking out of the trailer hitch you would really have to be careful about the terrain you drive over. If you're usually on paved roads on the way to where you put in, no problem. But if you're on steep or rocky Jeep trails, you could easily drag that thing or hang it up (vertically or horizontally). Think about trips you take and intend to take before you make your decision.
infinitereality
SLC IR/8
Louisiana
Mine are just typical sit on top yaks (Caster Perception), nothing special. While they're fairly durable, they do weight 60lbs. I don't think yours is as convenient to tie down as mine is, I just use the bed hooks and run it through the pole mount.
I'm following the thread to see your solution, wouldn't mind a easier way to carry it/them. Raptor is way easier to carry them than the roof rack on the wife's Terrain, I do know that. :)
amphibian
Midwest, US
Typically the rule is anything that extends more than 4' beyond the taillights should have a flag/marker on it.
I pull sailboats a lot and they tend to hang off the back of the trailer, and then the mast hangs off beyond that. Typically I'll tie both a flag and a little "bike flasher" (blinking red light) if at night. Keeps the guy on his phone and eating a sandwich behind you from seeing your taillights and thinking he's got 10' to go when really it's 5'.
ZBoater
ZBoater
Thats a good point. If I'm wanting to go to a secluded spot to kayak and the terrain is rough, that hitch solution might be a problem. If I'm just going to different marinas or launch spots where it's all paved roads, then no problem. I'll have to think whether I'll ever want to do that.
roybot
Los Angeles, CA
Hey all, I know I'm diggin this up from the grave but just thought I'd post here since it is a relevant thread. Found a used TracRac on CL and picked it up. Fits great on the truck and perfect for carryjng my boards. I want to modify it to make it more functional and aesthetic. Here is what I hope to do:
1) cut crossbars shorter
2) shorten the vertical arms so that the crossbars lie just above the third brake light
3) powdercoat it black
4) add some supports for the crossbars like some of the other Thule racks
5) Figure out a way to attach it to the bedsides in a way that would allow me to use my BakFlip. Was thinking of mounting Ltrack on my bedsides and then drilling holes in the feet of the rack.
101,310
60,412
hugecrankfonz
