Can we talk rim rub?
Discussion in 'Ford Raptor Exterior Forum [GEN 2]' started by Guy, Mar 12, 2018.
  1. Guy
    Guy FRF Supporting Member Supporting Member
    1,120
    653
    Feb 16, 2017
    I’m thinking of going with 18x9.5 +6 offset wheels with 305/60/18 true 35 inch cooper st Maxx tires.
    Is anyone running something similar?
    I’m going to go with 2 inch collars up front and stock height +2 deavers.
    I don’t want to get into a running mess. I could also go 295 which is 34.3.
    Thoughts welcome
  2. smurfslayer
    smurfslayer Be vewwy, vewwy quiet. We’re hunting sasquatch77
    3,425
    2,021
    Well... this post didn’t turn out anything like the title.
    :biggrin:
    ICLOSEM and k-rub like this.
  3. RDFTS
    RDFTS aka Rick Supporting Member
    12,470
    8,625
    Nov 10, 2013
    Southwest Missouri
    Sounds like a rim job is needed to get things to fit nicely
    ICLOSEM likes this.
  4. smurfslayer
    3,425
    2,021
    But ... what if things are just to tight for @Guy?
  5. Guy
    1,120
    653
    Feb 16, 2017
    You guys aren’t right.
    In retrospect I can see I should have said TIRE RUB. Anyway.... someone just answer my question. :)
    smurfslayer likes this.
  6. ICLOSEM
    ICLOSEM Full Access Member
    37
    66
    19
    Jan 31, 2018
    Title does read completely different. I wasnt sure if I should click on it or not. Then I just said F it and went for it!!.
  7. ChevyChad
    ChevyChad Full Access Member
    532
    220
    Dec 20, 2016
    You will be fine
  8. Guy
    1,120
    653
    Feb 16, 2017
    Chad
    Talk to me man.
    Define.... ill be fine.
    With the collars? Turning at full lock? Details man
  9. whan
    whan Full Access Member
    83
    23
    Jul 20, 2017
    Can't say I know for sure but think it'll be close but may be fine
    Normally on standard 17x8.5 a +6 offset with no lift is close, but likely doesn't rub in any turning scenario on level ground (some people have reported a 0 offset does slightly)
    Wider wheels push the outer edge of wheel out, but tire usually bulges out further than wheel, so it won't be 1:1 with how much further the edge of tire sticks out.
    I think ChevyChad thinks it's not much, if any at all - I would think it may be pushed out slightly at the widest point, I'm not sure though... depends on tire deformation
    Also depends on tire profile - yours is a true 35 so perhaps that may hurt as well / depends on sidewall lugs.
    All this to say I think it'll be close - don't think it'll be too bad if it does rub, and likely only at full lock
  10. smurfslayer
    3,425
    2,021
    I apologize @Guy, but I just can’t take this thread seriously anymore.
    This talk of collars and you’ll be fine but if it does rub it would only be at full lock...
    :biggrin::biggrin::biggrin:
    Yer killin’ me here Guy...
Share This Page
