GEN 1 Can someone tell me what this is?
Jhollowell
Everett, wa
Looks like I’m leaking something on the rear axle. Anyone know what I’m in for here? I just noticed it today so I’ll be pulling the wheel to see what’s going on
Passenger side
Drivers side
98rangerdave
High Desert 92392
I’m pretty sure it’s called a brake caliper noise damper, but honestly I haven’t seen one in a while. They might be common in different regions? But I’m pretty sure it has something to do with noise.
Sorry, I see the oil stain now. I could only see those large circular drums sticking off the caliper at first. Sorry I shared the wrong info, I’ve owned 2 f150s and worked on a handful more and never seen those caliper noise dampers. Maybe I’m the odd one out? Are those more common?
MTF
Celebration, Florida
I'm sure the parking brakes are saturated and need replacement.
And if the leak is getting to brake pads then that's a big problem.
If it's the caliper, I'd be very worried!!!
Booth9999
Idyllwild
I honestly wouldn’t even worry about it. Until you have fluid dripping on the ground, it’s not going to impact driving the truck.
What! Not too good advice, axle seal is out have it repaired and save the problems down the road.
B E N
Frederick, CO
Really not anything to panic about. Unless your actively dripping oil or see it getting on brake system components it isn't a big deal. 10 year old trucks, stuff leaks.
II Sevv
Arizona
Unless you’re driving through water and sucking debris up into your axle, it’s not going to grenade anything to drive on that. It never hurts to clean parts off and give it some time and see what happens with it.
