Cam Phaser Replacement, No noise
svt10th
SoCal
So I took my 2018 with 36K miles in to the dealer to have the 21N08 done cause I had a very slight shudder after getting the 21N03 done. When I picked it up the Service advisor asked if I had a Rattle at start up and I said no which I don't. He then offered to replace the Cam Phasers anyways and said he would order the parts and get me scheduled in. My question is should I have them replaced even though they aren't making any noise at the moment or should I just wait until they do? It was a CPO truck and I got the extended warranty 7 years 100K
Thanks
GMEN92
Ny
F369B75D-3FE4-4CE6-A3A6-4B24E4417708.pngWhat’s up guys just noticed i got this notification for my 2020 raptor
Is this more of a scheduled check up for the known issue ? Thanks
GMEN92
Ny
No. Those are extended warranty coverages. If you already had 21B10 completed them no additional action is necessary.
Ok thanks
Yea i bought it used last month
It’s a 2020
Date on the Window sticker shows 11/19/19 so i was assuming and hoping i was part of the newer ones that built after the issues..
I know when i took it in for oil change they said all was good but not sure if it was the 21B10 ?
melvimbe
@FordTechOne I've heard you say that the cam phaser is covered with extended warranty. Are you stating that Ford is warranting the cam phasers beyond 3 year/30k miles, and if so, what is the warranty period? Or are you saying that the issue is covered if you purchased an extended warranty?
r3run33
hello posted in the general discussion about the cam/phaser etc; would love to see something from ford in writing on how long these will be covered. My original problem was 11/2020. has issue rattle come up about 3 weeks ago. truck in for repair now. I'm covered for the repair because its under 1 year for service. but would love to see the actual extension of the warranty.
FordTechOne
Detroit
They’re covered by base powertrain warranty, which is 5 years/60k miles. For those out of powertrain warranty, program 21N03 extends that coverage to January 1, 2023 and up to 89,999 miles. That coverage is pro-rated; up to 69,999 miles is 100% covered, up to 79,999 is 66% covered, up to 89,999 is 33% covered.
The coverage in 21N03 only applies if you have 21B10 completed by February 28, 2022.
