Boomba BOV light check engine
Dirtypope
Chicago
After few days from installing the Boomba turbo blow off adapter the light check engine went on. Does anyone else experience the same problem?
It’s a 2019 raptor. By the way the sound is amazing!!
xrocket21
Maine
It really shouldnt throw a code. Maybe the plug is loose? Check your connections. Do you have a way of reading the actual code?
Otherwise, just reset and hope it doesnt come back. These trucks are so friggen sensor sensitive.
Dirtypope
Dirtypope
Chicago
The connector was loose. I accidentally damaged the clip from the connector while I was removing it. Any idea where can I order the connector plug and if there is any way to reset without the accessport? I’m waiting for COBB accessport but it’s not available yet for 2019
xrocket21
Maine
Finding the connector could be brutal... I bet its part of a whole harness. Plug it in and electrical tape it?
You can reset by unhooking the negative terminal for 30 seconds.
Dirtypope
Dirtypope
Chicago
Little silicone adhesive sealant and full tank of gas did the trick.
Dirtypope
Dirtypope
Chicago
full tank of gas?
no battery reset?
Someone post this on cargurus:
“If the repairs solvethe problem the light will go out on it's own. To speed up this process keep your gas tank between 3/4 and 1/4 full. No more and no less. That way the computer can run all the diagnostics. If it's still on after a week of normal driving there's something else going on. HTH. -Jim”
After I fixed the problem I only had quarter left of gas. Tank up and the check engine reset it self
MEATSWORD
Arizona
You have a link to the adapter?
Everything I see just didn't seem right.
Dirtypope
Dirtypope
Chicago
Like xrocket21 said it seems it was a loose plug. Also the adapter was not releasing air.
Now everything is back to normal. Hopefully the connector would stay on
