  1. angusmcraptor
    angusmcraptor Member
    28
    3
    Sep 8, 2018
    Miami, FL
    Comparing the differences between the BF Goodrich KO2 LT315/70R17 and the 35x12.50R17, the math shows only a 0.6” difference in height and a 0.1” difference in width. Is this what to expect when you actually mount them or is there a more noticeable difference?
  2. 500mag
    500mag FRF Supporting Member Supporting Member
    293
    126
    Mar 22, 2019
    Georgia
    Bigger is always better....
  3. gordo
    gordo Full Access Member
    51
    17
    Oct 7, 2019
    Ft Liquordale
    there are a couple posts on here I read that say exactly the same thing. do a search.
  4. TXRaptor
    TXRaptor FRF Addict
    1,272
    515
    Sep 15, 2010
    Go big or go home!
    J/K, I would get whichever ones are the best price, as you will not notice the slight difference in size.
  5. Jmythehead
    Jmythehead Member
    43
    45
    Sep 4, 2016
    Eastern Pa
    The difference is the load range. The 35X12.50R17 is a load range E (10ply) the LT315/70R17 designed for the Raptor is a load rance C (6ply). You will notice a bit harsher of a ride with the 35X12.50 if you care about that type of stuff.
    Flash1034, jzweedyk and CoreyMac like this.
  6. Vegas_Sirk
    Vegas_Sirk Full Access Member
    170
    61
    Oct 17, 2017
    Boise, ID
    This but you can run the E rated ones at around 30 psi vs the C rated ones (35-38psi) and make back up some of that comfort. Also the E rated wear evenly at 30 PSI on a Wrangler so I would assume the same on the Raptor.
  7. lngebrown
    lngebrown Member
    28
    7
    Sep 12, 2010
    Anyone run the E rated just on the rear for towing?
  8. Vader
    Vader Member
    Sep 11, 2017
    Cypress TX
    I went with the 35X12.50R17 this time around. Not much different, slight rubbing at fulll lock in the front that wasn’t, there before but it is just the inner fender well.
  9. Wolfeman
    Wolfeman Full Access Member
    336
    192
    May 15, 2016
    On my 2017, I ran the 35x12.5-17 and didn't notice much of a difference at all. Never noticed any rubbing either.
  10. Sunchild714
    Sunchild714 Member
    41
    25
    Apr 14, 2019
    Las Vegas
    You won't notice a difference. The 35's weigh slightly more but you'll feel that more in your head than you will at the steering wheel. I went with 35's because it was a whole $60 more for a set of 4. I wanted the stronger sidewall since I do a lot of off-roading and deflate.
Share This Page
