best width/offset for fender flush
Discussion in 'Ford Raptor Wheels & Tires Forum [GEN 1]' started by 1fastk, Nov 18, 2015.
Sponsored By: Texas Motorworx
  1. 1fastk
    1fastk Member
    17
    6
    Nov 18, 2015
    Im getting some wheels for my 13 SCrew and have narrowed it down to two different wheels...20x9 ballistic jesters or 20x9 american outlaw hollywood....I want the tires to be flush with the fender flares so im not sure of the correct offset to get...the jesters come in offsets of -12, -6, 0, 12 and the hollywoods come in a -10 and a 15....Just as a FYI im up on mid perch as well....Anyone know what the (best) offset would be to achieve this without scrubbing or with minimal scrubbing as possible.
  2. svt_reid
    svt_reid Full Access Member
    341
    90
    Feb 4, 2015
    north florida
    Most people on here will say 17 inch method wheels, which are zero offset. That's what I have and they stick out just past the fenders. definitely don't do go with a negative offset. Or you will be replacing all your front end joints
  3. Bulletnjm
    Bulletnjm FRF Addict
    6,385
    3,773
    Mar 31, 2014
    New Jersey
    0 offset gives it just the right stance
  4. svt_reid
    341
    90
    Feb 4, 2015
    north florida
    And a 17 inch wheel looks so much tougher than a twenty ;)
    LekRap likes this.
  5. LekRap
    LekRap Full Access Member
    973
    533
    May 17, 2014
    Corona, CA
    Agree that 17's are a much better option for our trucks. Maybe an 18" wheel would be a comprise for you if you want "big wheels" while still maintaining offroad function.
    @LEEHWCAP would be the guy to ask about offsets. I personally like a 17" wheel with zero offset like a Method...does give a sweet stance to the truck...get em and you'll understand when you first see them on the truck
  6. 1fastk
    1fastk Member
    17
    6
    Nov 18, 2015
    thanks for the input guys, most offroad my truck will see is a dirt road once or twice a year at the most so losing some functionality with going with a bigger wheel is no problem for me. The guys at work call it a pavement princess because I wont take it mud riding with them lol.
  7. 1fastk
    1fastk Member
    17
    6
    Nov 18, 2015
    Now after thinking about it if the method wheels (which im assuming is the 8.5 wide after looking at their website) with a 0 offset sit out slightly past the fenders. The jesters with the 6 offset should sit the exact same on the truck as the 0 offset methods. Here is how I came to that conclusion. The methods 8.5 inch wheel with 0 offset will mount at center which is 4.25inches. The jesters which is 9 inches wide with a 0 offset would mount at 4.5inches. Ok so now with both wheels being 0 offset the jesters will stick out .25inches further than the methods. Now the jesters need a + offset to bring the wheel back under the fender well to match the methods. 25.4 millimeters is in 1 inch I will need +6 offset for each quarter inch. So that means the method 0 offset and the jester +6 will sit the same on the truck. svt_reid said his 0 offset methods stick out slightly past the fenders so to get the tires flush with the truck the +12 jesters will sit inside the fenders 1/4 inch or 6 mils more than the 0 offset methods.
  8. The Macf
    The Macf FRF Addict
    6,776
    3,886
    Sep 17, 2012
    Utah
    I have the 18" Mesh with a +18 offset and 12.8" wide Duratracs.
    LekRap likes this.
  9. PacificWheel
    PacificWheel Full Access Member
    35
    936
    434
    Feb 7, 2014
    Reno, NV
    Tires play a big role in this equation. An AT will small sidewall lugs will protrude less than say a Toyo MT or Nitto Trail Grappler. BTW the Jester isn't made in a +6. It's a +12 or -12. Also your back spacing calculations are slightly off. The math is good but wheels measure from bead to bead not lip to lip. A 9" wide wheel will measure 10" lip to lip. So an 8.5 +0 is 4.75" back space and a 9 +00 is a 5" back space. For the easiest offset comparing just use this link below. If you need Jesters shoot me a PM. I'll hook you up.
    Wheel Offset Calculator | Tiwing.com
    LekRap likes this.
  10. The Macf
    The Macf FRF Addict
    6,776
    3,886
    Sep 17, 2012
    Utah
    [​IMG]
    [​IMG]
    [​IMG]
    LekRap and RDFTS like this.
Share This Page
