I’m installing an Icom IC-2730A dual-band radio in my 2024 F-150 Raptor R. The radio can draw approximately 13 amps when transmitting at full 50-watt power.
I’m trying to find the safest and cleanest way to power it without damaging the truck, drilling new holes, or creating reliability issues. I also do not want to use the visible 12V cigarette-lighter socket.
I’m currently considering three options:
This would be the cleanest factory route, but the wires appear to be only about 1.0 mm². I am concerned that a radio drawing around 13 amps at full transmit power could cause excessive voltage drop or heat. I would still install an inline fuse close to the battery, but I do not want to overload or damage the factory pass-through wire.
For anyone who has installed a 50-watt mobile radio in a 2024 F-150 or Raptor:
My priority is a safe, reliable installation that can support full-power transmission without cutting the factory harness or creating water-leak, electrical, or warranty concerns.
Thanks in advance.
- Run the radio’s dedicated power cable through the factory rubber grommet in the firewall on the driver’s side.
- Use the factory B-group pass-through wires.
- Take power from the interior passenger-side fuse panel.
- Where did you take power from?
- Did you use the factory B-group pass-through wire?
- What wire gauge and fuse size did you use?
- Did you connect the negative lead to a factory chassis ground or run it elsewhere?
- If you used a firewall grommet, how did you reseal it?
- Are there any suitable unused or dedicated high-current circuits in the interior fuse panel?
- Do you have any photos of your installation?
Thanks in advance.
