Best way to clean the shocks
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by JustRaptor1, Feb 14, 2020.
  1. JustRaptor1
    JustRaptor1 Full Access Member
    100
    40
    Oct 3, 2019
    Florida
    What is everyone using to get the dirt off the shocks and keeping them looking new.
    I bought some degreaser yesterday from chemical guys but wanted to see if anyone has a good way of keeping them looking clean.
  2. goblues38
    goblues38 FRF Addict
    1,380
    1,192
    Oct 27, 2018
    STL
    10 second blast of 3200 psi water pressure.....good as new
    SVTWillis and SS308 like this.
  3. JohnyPython
    JohnyPython Full Access Member
    739
    457
    Oct 28, 2018
    Canada
    All purpose cleaner. Brush. Pressure wash off.
    SS308 likes this.
  4. Halo Raptor
    Halo Raptor Full Access Member
    333
    129
    Feb 12, 2019
    Monrovia, CA
    I use my pink mountain bike cleaner shit and a brush
  5. Dhowell
    Dhowell Member
    44
    12
    May 2, 2019
    Colorado
    is your mountain bike pink, or is the cleaner pink? Not judging....just asking. ;)
  6. JustRaptor1
    100
    40
    Oct 3, 2019
    Florida
    Cool try out the power washer even after a car was they seem dirty once they dry.
  7. Badgertits
    Badgertits Full Access Member
    959
    520
    Jan 24, 2019
    Ma
    I took wheels off gave em a coat of spray can automotive clear when new. Im not sure what metal is used for the body/housing, but assuming it’s stainless. I had bilstein 5100 leveling shocks on my last 2 GM trucks- first set wound up getting oxidized/rusty overtime- not like raw steel flaming rusty- like rust stains- turns out those had 400 series (CR steel- no NI content) stainless housings. They won’t rust through, but looks crappy over time. I assume if I really cared you could probably use some metal polish & bring em back to better than new- but not really worth the time on a DD truck- so that’s why when I ordered a set for my 2nd truck I use the rattle can clear before installing.
    Again- not sure about these fox shocks tho, if you wanna check see if there’s magnetic draw if yes then 400 series if no then 300 series & wont oxidize/pit
    another good coating product especially for bare AL/stainless stuff (and honestly anything under the hood wires-plastics-rubber included) is Yamashield marine protectant (used to be called boeshiele T9) - it goes on clear & dries to a slight sheen - is not as permanent/heavy duty a coating as Amsoil HDMP, but it won’t discolor anything, can be removed if need be, & is also good as an undercarriage or Underhood “dressing” like Griots undercarriage spray- car show dudes use it, but main application was for Yamaha marine engine/crafts
  8. alex zopp
    alex zopp Member
    18
    3
    Feb 8, 2020
    haydental (north italy)
    there are products specifically for shocks , often found in mountain bike shops because bike shocks are more delicate
  9. Donovan
    Donovan Full Access Member
    838
    205
    Aug 10, 2019
    DC
    Simple green
    Purple power
    POWER washer. Done.
    Halo Raptor and MFNG like this.
  10. allinon72
    allinon72 Full Access Member
    349
    328
    Jun 1, 2019
    Indianapolis, IN
    When I recently replaced my shocks, I ceramic coated them.
    Halo Raptor likes this.
Share This Page
