Best Stance I've seen on 35's
combatninja
Too much poke up front but the rear looks about right. That's going to throw rocks and debris all over the sides of the truck. More for hard parking at the mall than real use. I'd go +5mm in the rear and +12mm up front. But then you're into a situation in which your fronts and rears don't match so you can't rotate as you'd like. I'd probably look for a +12mm all around if I were doing it.
