Best settings for B&O stereo
SD1290
Seattle
Hey All, just got my raptor. Does anyone have any recommended settings to get the most out of the stock B&O system? I changed from stereo to surround and that made it slightly better. I don't plan to upgrade just looking for settings to maximize the stock sound
Thanks
GCATX
King Dingaling
Central Texas
All I have for you is turn the fade a little to the front of the truck. Anything beyond that it gets real quiet. Then set the equalizer to your liking.
S
SD1290
Seattle
Where is the equalizer? Is that just the midrange, treble and bass adjustments?
lawdog
This depends on your tastes, but the EQ stays the same regardless of input, which can be an issue because each input is so different. Satellite radio is so compressed and mid-rangey, it sounds very different from a CD or iPod, etc. My old Tundra let you set the EQ for each input, which I liked a lot.
The "best", clearest sound I get out of mine is sending a pre-equalized signal from either my iPod or iPhone, usually the "Rock" or "Treble Booster" setting, and then setting the EQ from there. I boost the treble again, cut the mids and slightly cut or leave the bass alone, depending on style of music. Play around and see what works for you.
