Best Front Suspension Upgrade
Coyote Raptor
Cypress, TX
I am in the process of building out my Gen 2. I will eventually move to mid-travel suspension, but for now, am looking at more affordable upgrades to the suspension. I am in the process of adding an Icon bump stop kit, Deaver leaf springs (+3), and shackles (+2) for the rear end (the +3 Deavers add 1 inch, and the +2 shackles drop 1 inch, so the rear end should be stock height but have more travel). I am debating what route to go for the front end. I don't necessarily think I should do 3.0 shocks given the cost and that I will be upgrading to mid-travel in around 2 years. Any thoughts and/or suggestions are much appreciated.
San Diego
Depends what mid travel you're going with. BMS, RPG, Evil +2 and Camburg use 3.0 replacement so you could put that shock on now. If your going SVC or Evil +3 that use normal coil overs then like mentioned above slap some Geiser or Eibach coils on your current shocks and call it good until its time to put your kit on.
LordxEkim
Louisville, KY
I see a lot of eibach recs on here but on you tube the off road guys say geisers. Progressive or not is big difference right?
TomDirt
Hesperia CA
Well, Geiser only does offroad springs, they are in the Arizona desert, where they can test in brutal terrain. Eibach is primarily on-road vehicles, and they develop in Germany. There's no German word for "hucking it". Thats why I bought the Geisers.
2slo4u
Utah
Speaking from experience, if you lift the front end at all, you’ll want to go ahead and put the shorter rear shackles back on. I have deavers +3 with the + 2 shackle. When I put on the the Fox Race series shocks on the front, it was higher than the back end
Coyote Raptor
Coyote Raptor
Cypress, TX
Yeah, I'm upgrading to fox race series this month and thought about that.
TomDirt
Hesperia CA
This is the ideal stance. Seriously.
