Lance Kirby
Hey guys,
I have a 2013 Raptor and have recently started to experience the problems listed in the title. First, and least concerning, is what sounds like a belt whining on start up. It is only noticeable driving with the windows down and the radio off. It does not get worse when turning the wheel so i do not believe that it is from the power steering pump. Are there any tips for figuring out which one is getting loose? The Vibrations comes from under the driver side foot well and seems to increase with speed. Although, if I hit a rise in the road with speed and use some of the down travel the vibration goes away until the weight is back on the wheels. I suspect its either the cv axle or the front driveshaft. It also seems to be amplified when turning My other issue is when I am reversing I can push the gas down approx. an 1/8 of an inch and not accelerate any, but if i push the gas down anymore it is like the drive line suddenly grabs and accelerates. Could this be related to the slip yoke, or is this issue steeming from something else?
