Bed cover drain holes
Chicagowin
Chicago
New guy question. What are you guys doing for bedcover drain holes? Do I use the holes that are in the bed already or drill holes in the plastic plugs that are in the lower corners of the front of the bed?
dmb359
Minneapolis
I didn't use the drain hoses on my MX4. I think typically if you use them, you drill a hole in the rubber plug in the front of the bed.
CDN_Raptor
Edmonton, Canada
BakFlip MX4.
I drilled holes in the plastic plugs. Note, if you have a spray in bed liner and the plugs are sprayed you need to take some care if you want to keep the coating on there. More for aesthetics than anything else.
