Baja Designs Triple Fog Pocket Kit (Pro) for 2021+ Ford F-150 Raptor
K9 EXPERT
Idaho
Nex
RIP CoronaRaptor
Washington State
K9 EXPERT
K9 EXPERT
Idaho
I saw those on the website, but I cannot determine if the lenses will fit the lights I purchase, regardless, I just bought two sets of two each, thanks for your help
SurfRaptor
Newport Beach CA
Can’t answer your question but I went a slightly different route. Either way you are going to be stoked! So much better than the factory lights. Huge difference and worth the money.
DMays
Tennessee
I just ordered the Baja Designs Triple Fog Pocket Kit (Pro) for 2021+ Ford F-150 Raptor, see attached link…https://www.4x4truckleds.com/baja-designs-triple-fog-pocket-kit-pro-for-2021-ford-f-150-raptor/
is there amber lenses that I can order as well? Initially I want to cover all three lights and ideally be able to snap the lenses on and off. If for whatever reason I cannot snap on and off, how can I replace the clear lenses with Amber? Thanks!
Those covers don't snap on and off. They are direct replacements for the lens itself. The rock guards snap on and off though. I personally prefer the lenses but if you want the ease of switching in and out the rock guards are what you're looking for.
K9 EXPERT
K9 EXPERT
Idaho
I just spoke with Baja Designs and you are 100% correct, thank you very much. I previously ordered the replacement lenses and now I ordered the rock guards as well. The lenses cost about $105 and the guards cost about $35. Now I have some other questions. Why do do prefer the lenses? The Baja guy told me one of the three lights can be hooked up to the fog light switch, or all three can be hooked up to the auxiliary switches. Apparently the kit contains everything needed. I forgot to ask if they are all hooked up to the auxiliary switches, can they be hooked up to separate switches? In other words, do the lights have the ability to be operated in pairs independently of one another?
K9 EXPERT
K9 EXPERT
Idaho
Great shot! I totally agree, it looks much better.
Littlefx4
Simple answer, yes. Your BD triple fogs can be connected any way you like. The knob that controls the fogs is rated at 10 amps. SPV makes a harness in which you can relocate the factory fog wire from the bumper to the set of wires behind the battery putting all of your connections in one spot. All 3 pairs can be wired to one upfitter switch or you can wire them in pairs to 1 switch if you like.
For example:
Fogs knob (10 amps) - open
Upfitter 1 (10 amps) - S1's
Upfitter 2 (15 amps) - Squadron Pro Spots
Upfitter 3 (15 amps) - Squadron Pro Wide Corners
Upfitter 4 (10 amps) - open
Upfitter 5 (5 amps) - open
Upfitter 6 (5 amps) - open...or
Upfitter 2 - All 3 pairs
DMays
Tennessee
I prefer lenses because dust and grime can't get behind them. With the snap on covers there is an air pocket between the lens and cover that could trap grime. As for the switch the harness will come with a relay. A relay allows you to wire all the lights to a switch without blowing the fuse. You can definitely wire the lights in pairs on different switches. You'll wire the trigger wire from the harness to whichever switch you want to use. Pretty straight forward once you learn which wire is which. Baja has a good customer service line for technical questions.
K9 EXPERT
K9 EXPERT
Idaho
For example:
Many thanks!
