Baja Designs | LP4 Shipping Now!!
Discussion in 'Ford Raptor Lighting Modifications Forum [GEN 1]' started by Baja Designs, Jan 9, 2020.
KC HiLiTES
  1. Baja Designs
    Baja Designs Supporting Vendor Supporting Vendor
    1,521
    875
    Apr 12, 2012
    [​IMG]
    The LP4 is the smallest variant in the LP line up but maintains all of the power and features of its siblings. The LP4 features a total of 8,750 lumens and a 200° spread of useable LED light.
    This light pumps out 7,050 forward projecting lumens and 1,700 lumens of dedicated peripheral lighting courtesy of our patented Integrated Peripheral Technology (IPT).
    To keep your light performing at its highest potential, the LP4 integrates our proprietary Direct Ducted Cooling (DDC) technology. This feature allows air to travel through the front of the housing, over the rear heat sinks - drastically improving cooling capacity and performance.
    With an amber day-time running light, the LP4 will fulfill all your lighting needs.
    Learn More - https://www.bajadesigns.com/products/LP4-Auxiliary-light.asp
  2. 4x4TruckLEDs.com
    4x4TruckLEDs.com Supporting Vendor Supporting Vendor
    1,339
    544
    Jul 18, 2017
    *2 thumbs up*
    We got plenty ourselves ready to go
    [​IMG]
    sixshooter_45 likes this.
  3. GLOCK26
    GLOCK26 Full Access Member
    50
    13
    Oct 28, 2019
    El Centro,CA.
    How much
  4. 4x4TruckLEDs.com
    1,339
    544
    Jul 18, 2017
  5. Dr_Chooch
    Dr_Chooch Member
    18
    3
    May 21, 2019
    Louisiana (Northshore)
    These would be sweet as A Pillar setup.
    Rob_D likes this.
  6. Ben Lucas
    Ben Lucas Member
    35
    24
    Oct 23, 2019
    Defiance ohio
    Are the side leds on both sides or can you get them single sided
  7. Raptor911
    Raptor911 FRF Addict
    3,733
    1,339
    Aug 9, 2012
    Ashburn, VA
    All LP lights have leds on both sides.
  8. raptor36
    raptor36 Full Access Member
    407
    124
    Jan 3, 2016
    I wonder what CREE led is found within the LP4...... curious to learn more about the light if you have any info.
  9. WRCRaptor
    WRCRaptor FRF Addict
    1,481
    886
    Feb 12, 2013
    Great Lakes
    I am temporally running a set of LP6s on the hood mounts until my bumper set ups comes in. The LP6 is a bit big for me up there and the LP4 would work size wise much better. The down side to the small side LEDs is that they create a lot of glare on the windshield and is visible from the passenger light so I have covered the inside LED sets with electrical tape for now. They can not be shut off so if I run a set of LP4s I would do the same.
    As for light out I would normally run a spot lens on the hood so I think a set of LP4s in spot would be very nice.
  10. stolleee
    stolleee Member
    7
    14
    Oct 3, 2019
    Memphis TN
    so how would you incorporate into a 19 factory setup?
Share This Page
