Baja Design Squadron 2.0 Pro Backlighting Issues (Circus Circus)
P0H0
O-H-I-O
Upfront I love Baja designs — However the recent Baja Designs backlighting on the Squadron 2.0 Pro has an issue that will leave you frustrated. However the regular light function is great, and I love the 41% increase in lumens.
So here’s what I’ve experienced with the backlighting — and let me say, Baja Designs may come out with a fix down the road.
The background light has several different color options. You turn the background light on and off rapidly until you land on the color you want and then it will set to that color after about five seconds. This works great for a single light, but if you’re like me, you have two or four lights on a harness — I did 6 behind the grill and 4 in the lower grill. I also did an excellent job of securing my wires with zip ties.
When you cycle two or more lights on and off, inevitably one or two may not trigger during a light change and they start to get out of sync with each other. It’s not fun taking apart the zip ties to power cycle one individual light that was out of sync. Well, no big deal right?
It gets worse…
I attached my background lights to the marker/parking light circuit. This ensures the backlights only come on at night when they can be seen. However, there are other events that also trigger the marker/parking light circuit such as using your fob to operate the door lock and key fob detected approach lighting. I had a few lights get out of color sync using the key fob, and even triggered a change with the approach lighting being activated as I walked by to put the kitchen garbage in the trash can.
In case your wondering, you can rapidly lock and unlock your doors for a light show.
You could just opt to run your background lighting all the time with the daytime running lights. I just don’t think the background lights are daytime running light brightness — I think they’re difficult to see during the day myself, and it’s a sure way to burn out your lights more quickly. I wonder what is the service life of the background light?
You could also opt to run the background lights to an aux switch. I suppose this works for some, but if you’re like me I pretty much used up all the aux switches. I would prefer they just work with the marker/parking lights.
Aux 1: Lower Grill 4 Squadron Pro Baja Yellow Lights + Inboard Fogs Baja Yellow S2 Pro
Aux 2: Behind the Grill 6 Squadron Pro Clear
Aux 3: ARB Compressor
Aux 4: StarLink Mini
Aux 5: Chase Lights
Aux 6: Rear Bumper Reverse Lights
Solution 1: I think 90% of us would be happy with just Raptor Amber as the background light color. Maybe offer a switch on the back of the light to turn off the background color selection and lock the current color?
Solution 2: Add a tap switch on the housing of the lights so color can be changed on the one light when it’s on a harness with others. Still not something I look forward to having to do every once in a while, but tying in with solution one would be very nice.
Solution 3: Rethink power interruption logic as the method to change colors.
I’m more than likely going to unplug my background lighting and only use during the Christmas holiday — I’ll match the house lights.
P.S. If someone from Baja Designs reads this would you please let me know if I can disconnect the lights for a period of time to erase the set color — revert back to default?
EricM
OHIO
Our LED pool light controller works the same way to change colors.
If they get out of sync, there is a method to re-sync them, and I've had to do it once.
"1. Turn lights ‘ON’ to confirm the color modes are out of sync.2. Turn lights ’OFF’ for 5 seconds or more.3. Toggles lights ’ON’ / OFF’ three times within three seconds - must end in ’OFF’ condition4. Leave lights in ’OFF’ condition for 5 seconds.5. Turn lights ‘ON’ and confirm that all lights are in mode #1, Soft Color Change"
Something like that might work?
Baja Designs
It gets worse…
Aux 5: Chase Lights
Hey,
Shoot me an email! We can dive a little deeper into the issues you are having. We appreciate the support and will get you all taken care of.
Best,
Brahian Herrera | Forum Sales & Support
Email: [email protected] | Phone: (760) 560-2252 Ext 201
P0H0
P0H0
O-H-I-O
Update: I spoke with Baha Designs, they have a firmware update in the works — from what I understand it will do the following:
1) Require more on off sequences before initiating color change - for example five times.
2) Introducing a lock sequence you can set after getting colors where you want them. This may incorporate several on off sequences coupled with waiting 5 to10 seconds between several more on off sequences to unlock.
3) After cycling three full times through all the colors the lights will revert back to default amber.
FirstFriday
Firmware update is live, you'll need to reach out to BD's service/warranty team to send them in. Mine will be on their way in for the update tomorrow.
"With the firmware updated we added the ability to permanently lock on to one color. Currently if you turn the back light on and off it will go back into color changing mode. With the new firmware you can prevent that by going through a sequence to lock the back light. Once the firmware is updated, we will provide instructions."
jbishop98
West of the Mississippi
Thanks for the update. Think I'll wait a few months longer to purchase some.
Specialtyperformanceparts
Hello!
I just wanted to let you know that we can send you the updated version of the lights right now if you reach out to me and mention this post before purchasing them. That way I can make sure to send you the reprogrammed version on your order. So, you don't have to wait a few months to get them with the update if you just call or text me to set up the order for you that way.
If you have any questions or need any help putting together an order for these lights, please just let me know. You can call or text me directly at 317 934 6778.
Thanks!
Sidney @ SPV Parts
info@spvparts. com
Baja Designs
@Baja Designs can you advise of the latest? I’m experiencing similar issues and looking for guidance. Frankly I just want to keep them at amber and that’s all. P.S. bought the lights from @Specialtyperformanceparts with their awesome marker lights power harness.
Shoot me an email and we can get the lights sent in for a reflash. We are seeing that turning on the back light on and off quickly, multiple times can cause the back light to go out to sync. You can send me an email, and we can reflash them for you, or you can also move it to a switch rather than the DRL circuit. Our New update can go on the DRL Circuit with no problem if you want to wire it that way.
Best,
RawrtorBaby
Raleigh, NC
Best,
Thanks mate, email sent!
101,284
60,415
Gerth
