Dr_Chooch
I’m getting ready to do a projector retrofit on my 2012 SCREW. I’ll be adding dedicated amber perimeter halos and rings.
It seems like tapping a fuse in the engine bay seems to be a dead end or just a general bad idea.
So I will run it off of my unused Aux 4.
So the question is should I still be able to use Aux 4 to power these new LED’ as well as tap it into the green and yellow BCM wire. In order to have the grill lights come on with ignition also.
Also I’m quite inexperienced with automotive wiring, but want to get better. I can just tap that BCM wire with a standard wire tap near the BCM pin connection right? I don’t need to try and pin both brown and green/yellow in the same spot right? I’m sure that was a dumb question but should give you an idea of who you are dealing with here.
And just so THAT GUY knows I’m aware “Just Forscan” I’m one of a few dozen out here who doesn’t own a PC.
I manage with a phone and a 13 yo MacBook Pro.
