Auto dimming high beams?
Discussion in 'Ford Raptor Lighting Forum [GEN 2]' started by bwmiller74, Jan 16, 2018.
  1. bwmiller74
    bwmiller74 Member
    44
    36
    5
    Sep 18, 2017
    Iowa
    I have a 17' 802A without the tech package. It does have the 360° cameras and Bliss. I had 17' Lariat that had the auto dimming high beams and kind of miss it. I see on the forscan spreadsheet an option for Auto HeadHigh Beam (AHB) control under IPC-new to enable. Is it as simple as just enabling it with forscan? I thought I read somewhere where the camera in the rearview mirror was the sensor for this feature. Just curious if it is that simple or even a possibility.
  2. crash457
    crash457 I'm Batman Supporting Member
    2,339
    1,866
    Aug 4, 2016
    St. Louis, MO
    The 802A has auto high beams. You just need to enable them in the settings in the IPC.
  3. NDO
    NDO Full Access Member
    53
    106
    36
    Feb 20, 2017
    You sure about that? I thought they only came with tech package.
  4. bwmiller74
    bwmiller74 Member
    44
    36
    5
    Sep 18, 2017
    Iowa
    I enabled it through Forscan and it didn't work. Changed IPC 720-01-01 xxx* xxxx xxxx. From B to F. It showed up on settings, but it was greyed out and I couldn't select Ok to turn on.
    User LivnitUp from f150forums. Stated 'You need the IPMA camera in the rear view mirror for AHB to work.'
    I believe what he has to say when it comes to Forscan stuff.
  5. HotLap
    HotLap Full Access Member
    359
    109
    Mar 7, 2018
    SoCal
    Interesting, I have the AHB on my 2016 KR and had thought it worked using the camera in the windshield underneath the Rear view mirror housing...as it looks forward into oncoming headlights and taillights as you approach from the rear? Same camera that the Lane Keep Assist uses to see the lane markings...
  6. Nick@Apollo-Optics
    [email protected] Supporting Vendor Supporting Vendor
    5,456
    1,842
    Apr 3, 2011
    Auto High Beams are only part of the Technology Package.
    Per the Ford site:
    Raptor Technology Package Includes:
    • Lane-Keeping System
    • Lane Departure Warning
    • Auto High Beam
    • Rain-Sensing Wipers
    • Adaptive Cruise Control with Collision Mitigation
  7. starkall
    starkall Full Access Member
    34
    407
    133
    Sep 19, 2013
    I never use my auto high beams. I found it to be kind of annoying.
    Booth9999 and dude1782 like this.
  8. Notn41
    Notn41 Full Access Member
    29
    78
    6
    Jan 7, 2018
    It’s part of the tech package only I believe.
  9. Booth9999
    Booth9999 Full Access Member
    39
    632
    146
    Nov 19, 2017
    Idyllwild
    I agree they are annoying, I live in the mountains and it is not very good at
    Switching them back and forth in the corners for oncoming traffic.
  10. NDO
    53
    106
    36
    Feb 20, 2017
    Interesting. I find just the opposite, they’re generally pretty effective for me. I especially like them when it’s a mostly deserted road and I’m using my aux lights relayed to high beams.
Share This Page
