Audison Audio Help
mwaite09
Nashville, TN
As stated, I have the compete audison sound system upgrade and having a weird issue with my audio sound, there is none. started when we hit -1 on 12/23. Screen and steering wheel controls work fine volume indicator works just no sound at all. For some reason the sub is not getting power as the blue power light does not come on
What I've done so far in order completed,
Disconnected the negative terminal for 5-7 minutes
Checked 20-amp fuse in slot 19
Checked 30-amp fuse on the sub
Checked the 2 fuses running to the positive terminal
Disconnected the positive terminal for 5 minutes.
I do know the audison amp has a 30-amp fuse but not sure that's the issue since everything works as it should minus the sound.
