Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
Are you ready to get Whippled?
Discussion in 'Custom Truck Shop' started by customtruckshop, Apr 30, 2014.
  1. customtruckshop
    customtruckshop LGE-CTS Motorsports Supporting Member
    934
    254
    Mar 12, 2012
    San Dimas, CA
    LGE*CTS Motorsports is offering deals on Whipple Superchargers!
    If you're thinking about getting a Whipple, now is the time!
    If you're in California, and get your Whipple installed here, you'll receive a FREE dyno testing for before AND after your Whipple installation just to see how much power your truck as gained. As well as deals on the product!
    Out of state? No problem! We'll offer deals on shipping and the product itself!
    If you know what you want, please tell me if you want the "Tuner" kit, or the Regular SC kit, as well as if you want it powdercoated a certain color.
    "Tuner" SC kit does not come with a programmer or injectors and is not California (CARB) legal.
    The Regular SC kit includes the programmer, injectors, and is California (CARB) legal
    PM me for more details and pricing!
    Here's the dyno result off a Raptor on Whipples' site!
    [​IMG]
    If you want to know what you're getting, here's the list of features Whipple has to offer!
    -Front entry W175ax (2.9 liters) Whipple twin-screw supercharger that significantly outflows competitions 2.3L roots-type systems
    -Integrated casting to minimize bolt on pieces, adapters, leaks and flow restrictions
    -Integrated Crusher ™ shaped inlet for maximum airflow capacity and minimal rotor cavitations
    -Integrated Crusher ™ 172mm oval inlet outflows smaller 90mm inlets such as other systems
    -Big Mouth Whipple Crusher ™ plastic air inlet for increased velocity and lower inlet temps vs. steel and aluminum tubes
    -Optional Crusher™ 172mm billet mono-blade throttle body
    -Integrated design allows for oversized intercooler core compared to other smaller intercooler cores giving Whipple lower air charge temps which allows more boost and timing to be run on pump gas
    -Massive air-to-water aluminum bar-plate intercooler offers more cooling than any other positive displacement system available
    -Whipple Superchargers massive oversized intercooled air-bypass system for industry leading reduction of burst knock and incredible fuel economy
    -Self-contained oversized oil system for dramatically reduced oil temps in even the most demanding conditions
    -Exclusive 3x5 rotor combo for significant increase in airflow under the curve than less efficient 4x6 rotor combo
    -Center discharge port for better cylinder to cylinder distribution then other twin-screws with cobbled together billet adapters and forward facing discharge
    -Discharge down design allows for less pressure loss which gives more power at lower boost levels
    -Top mount design allows for cooler operation then upside down SC’s that conduct heat from engine and are trapped by runners and covers, causing hotter manifold temps and less power per pound of boost
    -More boost at the “hit” than any other twin-screw
    -Flat torque curve for incredible acceleration
    -Oversized heat exchanger for incredible intercooler water temps
    -Fits under factory hood with no modifications
    -No internal modifications required
    -Completed installation looks factory installed, not some cobbled together kit with multiple billet adapters
    -Kits come complete with all necessary parts and hardware for installation
    -Unique oil level sight glass for easy oil level and quality check, no dipstick to bind or misread
    -Plug and play wiring, no cutting
    -High flow air filter system, coolant reservoir is maintained
    -High flow fuel injectors (63lb/hr)
    -Proven 6-rib belt system with heavy duty spring loaded tensioner and adjustable idler system
    -Stainless steel jack-shaft with unique plastic cover for increased safety
    -OEM quick connect fittings for easy installation
    -Complete and tuner kits available
    -Available in wrinkle black, polish or any custom color
    -Easily upgradeable with bigger throttle bodies (172mm or twin 75mm)
    -Instant boost at the touch of the throttle
    -3 minute pulley changes
    -1 year warranty for all parts included
    -Optional 3/36, 5/60, and 5/100 warranty
    WHIPPLE SUPERCHARGERS OPTIONAL PRODUCTS
    -172mm oval mono-blade billet throttle body
    -75mm twin-blade air inlet system
    -80 lb/hr fuel injectors
    -Custom colors
    -Pulleys from 3.75” to 2.75” in every .125 increment
    -Note: Specs based on 2010-2013 Ford Raptor, F-150, and F-250. Most vehicles come with these features listed above, but may have a few removed, or extra things added.
  2. customtruckshop
    934
    254
    Mar 12, 2012
    San Dimas, CA
  3. SARaptor
    SARaptor Full Access Member
    52
    8
    Aug 3, 2013
    Please PM priced shipped to 78254. Thanks in advance.
  4. bakkbakk
    bakkbakk Full Access Member
    643
    206
    Nov 23, 2013
    House
    wish I could get this done to mine. Ive been trying to find an installer that will come with the warranty whipple offers but nowhere even close to me. Plus if I had issues id like the installer to be close. Damnit
  5. DezertRacer
    DezertRacer Supporting Vendor Supporting Vendor
    631
    251
    Apr 18, 2014
    Las Vegas,NV
    Please PM a price shipped to 76052 on a regular sc kit
  6. Dv8tor
    Dv8tor FRF Addict
    1,374
    528
    Aug 15, 2012
    Detroit, MI
    Ah what the heck. Can I get a price and shipped to 48081. Also price me out the oversized heat exchanger, mono blade throttle body, and supercharger body in race red, to match the truck of course, please? Thank u in advance.
  7. customtruckshop
    934
    254
    Mar 12, 2012
    San Dimas, CA
    PMs sent guys! Thanks!:rockit:
  8. scoutdrivinrebel
    scoutdrivinrebel Full Access Member
    205
    38
    Mar 5, 2014
    DFW, TX
    I want Whipple so bad.
  9. Aggie
    Aggie Full Access Member
    145
    68
    Nov 6, 2013
    DFW
    Ah I see a fellow V owner... Of course you would be interested in a supercharger!
    Raptor why yu no fast like mi car!
    :yuno:
    Killjohnathan likes this.
Share This Page
