Hi XexarGreat install. I just went to lowes and bought a bunch of parts for my own install but i was going to go onto the frame near the muffler. How did you mount it?
CKMA12Sweet! Which ARB unit are you using?
I appreciate that Wayne. I did a quick dry fit in the space where you have it and it gets pretty tight. I'm thinking i'm going to move forward with the frame mount and super-strut. I'll hopefully have pictures to post in a couple of days. One other question. I'm going to wire this into an up-fitter switch which there is a ton of talk on here. But which ground point did you use?
Agree and disagree…Very nice install. But I do have two issues with it. One is engine heat, compressors heat up fast and engine heat is a problem. You can help by opening your hood when you air up. Second, the single ARB is a little light for 35" tires. It will do it, but if your really air down it will take a while to air up. I prefer the twin for the Raptor, and use the single on my RZR. Just my 2 cents. Again, very nice install.
