Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
2014 Gen 1 crew cab mount bolt is loose and I have no idea how to t remove this damper to tighten it. Maybe the bolt is under the rear passenger seat carpet? The other body mounts tighten from underneath the truck.
Nevermind they are Spring loaded. Push up with everything you got then twist so pins slide down slots then pull down. They have a small bolt retainer pin holding the onto the bottom of the bolt.
