Anybody run tire chains ?
Snowsled
Ridgway CO
There are always a few good snow days when the county doesn't get to plowing the road up to our riding area and chains are a must if you want to make it up the road.
I noticed the manual states no tire chains on the Raptor... My bad for not just looking, which I will do today but, who has run chains? I will have to buy a set for this truck and will go with lighter duty versions for fit and just the occasional need.
On my previous solid axle trucks I would run just fronts, on this truck I think all four might be a good idea given the additional joints in the front driveline.
Thoughts?
Snowsled
Snowsled
Ridgway CO
Snowsled
Snowsled
Ridgway CO
I see the problem... There is only about half and inch between the tire and the spindle/UCA. Guess I will be parking on the road those days...
14 BlackScrew RR
Chicago NW Burbs.
On dirt. NO!
On fresh snow, or packed snow. YES!
The next heavy snowfall around Denver, go up to Eisenhower Pass and you'll see them in action.
They are also approved by the western states that requires and enforce chain laws during the winter months for 18 wheeler.
BTW. .... For that amount of snow in the picture, you don't need chains.
You need a PLOW.
downforce137
In Diana
if you switch to aftermarket wheels like methods, it'll give the required clearance on the uca. stock wheels run pretty close to the suspension..
03Cobraraptor
I bought a pair from Tirechain.com
I live in Texas but always want to be prepared for travel up north.
Snowsled
Snowsled
Ridgway CO
On dirt. NO!
My application is dirt roads. On the plowed surface roads the KO2s perform just fine.
I avoid those places like the plague
GREAT!, not for my needs though, as I said.
You need a PLOW.
Nope, just a 4wd and a sled! Our access road is a couple of days down the list for the county. If you want the good powder days, you go up the unplowed road. Sometimes it works, sometimes, not so much...
Hockster
My 45ft Bluewater Party
Winchester, Va
In order to cross I 80 you must have a set installed on your vehicle so I imagine someone has had to do this
dixonk
HMFIC
Oklahoma
I thought 4x4 and AWD vehicles are exempt. Every time I came up to a chain checkpoint they let me through without them.
