GEN 2 Any experience with these-Autostop Eliminator For Automatic Start-Stop Switch
ddpt
ddpt
I have one on my 2019. Works. Easy install
Do you have to set the switch each time the vehicle is started or does it remember the setting and keep auto start off?
Sent from my SM-N960U1 using Tapatalk
docskeet1
Athens GA
The easiest and cheapest option is to unplug the trailer light connection beneath the dash (free). If you need the connection, for under $30.00 you can purchase an OBD connector and with a laptop using free software (Forscan) and a free license make a single change to a single line of code, and the ESS system stays off. You can do LOTS of other things with Forscan, and if you change your mind you can reprogram it back.
MEATSWORD
Arizona
I would recommend doing it with forscan, there are other settings you can change also.
Like horn honk with the keys in your pocket when you get out.
Also it's cheaper
Booth9999
Idyllwild
It Remembers the last selection. Best way to keep factory functionality but have it off. I haven’t turned it back on yet but I can if I get in traffic.
