Any deals on Baja S2’s and Evil Manufacturing Third Brake Light
Nick@Apollo-Optics
Adam, the MJ unit says no drilling. How does the antenna connect to the radio ?
The GJ units are made with or without an NMO antenna mount, but you do have to spec that option when ordering. The NMO is included so you just screw on your antenna when you want to run it. But you can take it off and cap it for daily driving and dealing with parking garages.
Nick@Apollo-Optics
BD has a coupon code for forums users giving 10% off, unless one of these other dealers give you a better hookup.
Our prices are already 10% off list and free shipping everyday. We also have additional deals and package savings available via PM and have a price-match policy on all other Baja Designs quotes.
raptor36
Not sure what % off the “together” coupon code on BD’s site gives. Might be worth checking out. God speed.
4x4TruckLEDs.com
The GJ Motorsports brake lights have the motion to get an NMO mount pre-installed. This mount is installed by GJ Motorsports and let's you screw your antenna right onto the bracket. There is an antenna cable pre-installed as well on the inside with enough slack to get all the way up to your center console on your truck.
Each GJ Motorsports kit also includes a basic harness which lets you connect the outter 2 lights to 2 different upfitters (or twist the wires together and go to 1 upfitter) while the center light operates like your factory cargo light (turns on when doors open, turns on when you disarm your truck, turns on when you turn your bed lights on, etc...)
Will the Gj Motorsports fit on a 2019...no drill? This light is a little pricey but looks awesome!
Yes the GJ Motorsports brake lights install without drilling any holes:
1st Gen: https://www.4x4truckleds.com/gj-motorsports-3rd-brake-light-for-2009-2014-ford-f-150/
2nd Gen: https://www.4x4truckleds.com/gj-mot...ght-for-2015-ford-f-150-2017-ford-super-duty/
I added two s2 Sports to the cart and it gave me $25 off of the order
We offer forum discounts, all you have to do is PM us with what you are looking for and we'll price it out.
roscopeeco78
Hello 4X4 LEDs.
Can you talk about a little about the functionality of the different wiring harness packages.
4x4TruckLEDs.com
Basic Harness
This harness provides integration of the 3 marker/brake light LED's with factory wiring harness as well as connecting the center light to the cargo light circuit. Two additional circuits are provided to connect the outer lights to the factory upfitter switches in the passenger kick panel.
Reverse Light Harness
This harness has all the features of the basic harness, but also connects the center light to the brake light circuit so that it comes on automatically when the truck is placed in reverse.
Stop/Tail/Turn Harness
This harness includes a stop/tail/turn controller to integrate the outer to lights with the factory brake/turn signals. It includes inputs for connecting to your aux switches for:
  • Master power to turn the system on/off
  • Stobe Function
  • Strobe pattern change (momentary switch to be optionally mounted in the dash)
  • Constant on override to disable the turn/brake integration
Stop/Tail/Turn Harness with Reverse
This harness has all the features of the Stop/Tail/Turn harness, but also connects the center light to the brake light circuit so that it comes on automatically when the truck is placed in reverse.
Nick@Apollo-Optics
No drill at all. Everything bolts together and is all plug-and-play. We can also fully customize your lighting setup and your wiring harness so you'll have exactly what you need.
Just shoot me a PM and we'll take care of it.
