Hawgdriver
Hey Guys,
Sorry for another up fitter question but i'm stumped.
Here's my setup on a 2014 Raptor:
Aux 1: 40" Rigid light bar white light (bottom row) - Yellow Wire connected with Purple pass through wire
Aux 2: 40" Rigid Light bar amber light (top row) - Green/Purple Wire connected with Green pass through wire
Aux 3: White Rigid Cubes
Aux 4: Amber Rigid Cubes
I've had these lights operational for a couple of years now.
A couple months ago the bottom row of my 2 row Rigid Light Bar started to be intermittent.
Within a couple of days the bottom row, running off Aux 1, stopped working.
Based on the indications I quickly assumed the light bar went bad so I sent it to rigid.
Rigid returned the light bar saying it tested good but they replaced some parts and the front lens.
I remounted the light hoping it would function normally, but it didn't.
I've tracked down as much as I could but what am I missing???
Here is what I've checked:
Fuses #18 AND #19 check good (swapped them to ensure)
Main Relays check good (swapped them to ensure)
Relays in the separate relay box under hood near driver side windshield check good (swapped to ensure)
When I flip the Aux 1 switch it sounds like it triggers the relay.
With a tester I know I have power to the Yellow Wire, the Purple Wire, the Green/Purple Wire and the Green wire under the glovebox.
But here's where it gets crazy and I can't find the solution....
When checking the wires under the hood/after the pass through wires pass through the firewall in the large wire bundle...I have power to the Green Wire but I have NO POWER TO THE PURPLE WIRE!!
HOW IS THE PURPLE PASS THROUGH WIRE "HOT" UNDER THE GLOVEBOX BUT not HOT UNDER THE HOOD?????
Please help, it's driving me nuts!!
Thank you!
Thank you!
