GEN 1 Amp Advice
Raptized
Raptorida
Hello everyone. I am far from a Electronics expert when it comes to Car Audio. In my Heyday you got the bigger speakers you can fit in your car with the biggest amp you could afford and that was your system. Today I found a first generation kicker Solo-Baric sl10 brand new in box in my garage that I was going to install in my old Chevy truck. I want to use the smallest box I can for my truck and the only information I can find is that it's a 600-watt speaker and it has dual 2 ohm voice coils.
What kind of amp specs am I looking for for good sound?
2013 Supercrew
Smokeshow60
SgtMajor of the MemeCorps
Southern Ohio
2013 Supercrew
Amp spec that best represents would be the amps spec on "harmonic distortion " the lower the better
Smokeshow60
Southern Ohio
Thank you for the reply. English? Lol
Lol. You asked what specifications you should be looking for. If you look at the listed specifications for any amplifier the advertised harmonic distortion is the one that basically tells you how clean it is. The lower the harmonic distortion is the cleaner the power is that's delivered to the speaker. The cleaner the power, the better it will sound.
Raptized
Raptized
Raptorida
OK. What watt range, size, channels and anything else would be ideal?
Raptized
Raptized
Raptorida
Gotcha.. ignore that. Put the rated power at the rated ohms to the speaker
I will run a single 10. Here is a pic of the wiring from the owner manual. So do I bridge the amp? Lower ohm wiring better? I can't find an rms rating anywhere. dac7668ebb4f8e869714ca9724b6edd7.jpg
Smokeshow60
Southern Ohio
I've never used a setup like those... gonna need some help from someone that knows more than me... sorry
