I had the Icon adjustable collar installed at the 1.5” height. This applies 1” of preload to the springs and gets 1/2” of height front the spacer on the shock tower.
When I left the shop, wheel is slightly to left and definitely needed a alignment. I had the alignment done at Ford, they were able to get all settings into the green but something is still not right.
I am having wear on the inside of the front tires, steering wheel is back to the left some , and feels “light” over bumps and compression/ rebound .
I know it needs to be checked again, looking for some feedback and if the spacer on top of the shocks causes a problem. I did do a search, but only came up with Geiser settings .
Thanks.
Thanks.
