Air bags
Raptor8541
Tucson
Hey guys. Got a 2019 Raptor here. I wanna add some airbags to the back so that when I load the truck bed up I won’t get too much sag. I want to add something, but not mess with the stock suspension. So when I take the load out, it rides like it’s supposed to. Any suggestions?? Should I do air bags? Is there a better way of accomplishing this? 48E3C8C3-3EE5-409E-BC4F-0C3B1D08EBB3.jpeg
Jakenbake
I personally would prefer deaver’s (note that they can make custom packs for you if the SD and HD doesn’t fit your need) as the benefits outside of the use case you are describing would be nice.
But if you want a solution that is removable, there’s a thread floating around here that someone added some secondary rear shocks mounts and ran an air shock with quick release pins for removal when not needed.
Also I believe Carli has some long travel air bags for their superduty kits. Could consider a retrofit of those as well.
CoronaRaptor
CANADA
Welcome to the place. Beautiful scab!! I have deaver plus 3's on my scab, does not ride harsh at all, best money I ever spent on my truck, I have hauled quads and dirt bikes in the back, concrete blocks, towed 21' trailer and loaded box, no issues what so ever. Get the size of deavers you require for your needs, they come in different applications just for that reason.
