IndianaRaptor
Indiana
Looking to improve the towing on my 2018. I have Eibach springs up front and Icon multi rate leafs in the rear. The rear is set at option 1 currently.
Option 1 - Change the Icon over to option 2 or 3 with an extended shackle to keep the truck somewhat level.
Option 2 - Leave the springs how they are and add in airbags. I’ve seen where some people mount just the top of the bag and then mount a cradle on the bottom so it won’t impede suspension travel.
Mystic_2003
I have a 2018 as well.
Current setup is stock front springs. I had tried eibach, but went back to stock.
Deavers +3HD on the back with lowering shackles. Part of the reason I went back to stock springs on the front end.
Added Live Valves and SDI EClik and when I tow I crack up the towing gain. Essentially it stiffens up the rear.
Tows beautifully.
Aluma 1000lb trailer and RzR about 2,400lbs. Easy peasy.
Also a 8,000lb boat, I don’t go far and ended up putting electric over hydraulic brakes as I hated the clunk on the surge brakes.
Tows it like a champ.
The amount of money to do this was silly. I could have bought a beater 3/4 ton.
Mystic_2003
I don’t know the icon setup, but I do know that the eibach’s raising the front end is not helpful when towing.
Mystic_2003
RPG +2 with Deaver +3HD puts the truck leveled with the stock front springs.
Personal Opinion: lifting the truck is not helpful to the geometry of the shocks and suspension. Yea it looks cool, but that’s it
DAVfoto
Clifton NJ
Start with upgrading the rear springs with drop shackles.
I don’t remember what level my Icons were, but I had a drop shackle.
(Picture was before I found a 11" drop hitch)
From looking at this picture, you were easily level 2 and maybe even level 3 with the drop shackles. My rear looks about the same height as yours with level 2 and no drop shackle with 37s.
Level 2 doesn't move a ton with weight, 500-600 pounds of tongue weight will drop it about an inch to 1.5" but not much more than that.
