aFe Raptor Transmission Pan NOW SHIPPING!
Discussion in 'Freedom Motorsports' started by [email protected], Jun 17, 2014.
  1. Chris@FreedomMotorsports
    [email protected] FRF Gofur Supporting Vendor Supporting Member
    46
    3,005
    2,495
    Oct 4, 2012
    Woodlawn, Virginia
    THEY ARE SHIPPING NOW While Supplies Last! The New aFe Power Ford Raptor Deep Transmission pan.
    [​IMG]
    aFe Power's new deep transmission pan brings performance engineering to the protection of your 2009 to 2014 Ford truck's 6R80 transmission. aFe's transmission pan adds an additional 7 quarts over stock. Internal and external fins transfer heat from the fluid to the ambient air for maximum cooling. This transmission pan is constructed out of durable A380 aluminum with reinforced ribs for maximum strength. This pan also features a black, powder-coated finish with machined fins for protection and styling.
    Internal and External Fins: Internal and external fins transfer heat from the fluid to the ambient air for maximum cooling.
    Magnetic Drain Plug: This system incorporates a large neodymium magnetic drain plug that captures loose particles for maximum transmission protection and can be tightened using a 1/2" square socket drive.
    1/8" NPT Port: Threaded 1/8" NPT port comes ready to use for your transmission temperature sensor.
    Hassle-Free Installation: Transmission pan comes complete with all necessary hardware to bolt directly to factory location for a hassle-free installation. Compatible with stock filter and able to reuse stock factory gasket.
    When it comes to engineering for power, performance, protection and value, aFe Power is the only choice.
    Get YOURS TODAY at the link below!
    https://raptor-svt.freedommotorspor...product_info&cPath=1126_1331&products_id=1826
    pat'sRAPTOR and NickPic83 like this.
  2. SVT_4X4
    SVT_4X4 Full Access Member
    515
    255
    May 3, 2012
    Linden, MI
    Has anyone installed one of these yet? I have one and have some concerns. There is an a sump adapter you are supposed to put on your filter. I bought a new filter from Ford and it wont' fit. When I called AFE they said per the instructions it does not need to be used on all applications but I am not satisfied with that.
Share This Page
