ADD pro bolt on ACC relocation light bar
VGKRaptor
Las Vegas
If you relocate the ACC with ADD pro bolt on bumper can you have a BD S8 light bar behind the grill ? Or does the relocation of ACC get in the way ? Thanks for feedback.
OffroadAlliance.com
Boston, MA
It will most likely block part of the sensor. Depending on the kit you buy, the ACC sensor is relocated to above the F or above the D in the grille. If you had a light bar that is placed just over the O and R then you might be able to get away with it.
