ADD Lower Control Arm
ADD GARY
Here we go again everyone... We are releasing our Lower Control Arm for the Ford Raptor. This is how the official Press Release will read:
Addictive Desert Designs leads the market in innovation and we are proud to announce the release of our new Lower Control Arms. After several months of research and development with experience from the top people in the racing industry we have built a lower control arm that will change the Raptor market. This new Lower Control Arm will not only enhance the drive of the vehicle, but upgrading it will make it handle better, offer more predictable controlling, and allow you take even heavier abuse in your off-road adventures.
The ADD Lower Control Arm will work with a stock shock or aftermarket shock and the arm can work with a stock spindle or can be upgraded to our new ADD Spindle. It is made using 3/16” steel plate, Race Quality Bushings and Stainless Steel Spacers making it the strongest Lower Control Arm on the market
Furthermore, it was developed to accept a stock shock, an aftermarket 3.0” shock, or our dual Fox Racing 3.0” bypass setup for total control and adjustability. The engineering team at ADD spent a great deal of time perfecting the geometry that was needed to make the best optimized product for your off-road adventure and racing needs. The arms are CAD designed, laser cut, built in precision jigs, powder coated grey and are ready to install and are complete with all the necessary hardware and spacers you will need. Combine this with our new 2010-2014 ADD Ford Raptor Replacement Spindle, FOX 3.0 Coil-Overs, and bypass shocks to take your Raptor Suspension to the next level.
ADDGrant
Arizona
Additional pictures:
ADDGrant
Arizona
Couple pictures of the new LCA being made:
ADDGrant
Arizona
Our new LCA & Spindle are getting installed today. More pictures and a detailed write up will be coming shortly.
ADDGrant
Arizona
do those inner bushings have grease zerks?
No. They are self lubricating but prior to installing control arms make sure to remove bushings and use a motor cycle chain lube tri flow its a dry lithium graphite compound.
ADDGrant
Arizona
LCA & Spindle
