Adam's Polishes NEW Ceramic Spray Coating
Discussion in 'Adam's Polishes' started by AdamsPolishes, Jan 9, 2019.
  1. AdamsPolishes
    AdamsPolishes Supporting Vendor Supporting Vendor
    3,034
    2,218
    Mar 15, 2013
    Introducing Adam’s New Ceramic Spray Coating!
    Adam’s Ceramic Spray Coating combines the enriched gloss, extreme hydrophobic properties, and effects of a ceramic coating with the application of a spray and wipe product. This 9H ceramic coating has been reengineered to be sprayed out of a bottle and wiped onto the surface, making application easier than ever before.
    Use discount code COATING to save 15%
    CLICK HERE TO SHOP
    [​IMG]
    Check out the video:
    Introducing Adam’s Ceramic Spray Coating, a game changing product in the ceramic coating world. At a registered 9H Hardness, Adam’s Ceramic Spray Coating is the easiest and fastest way to ceramic coat your vehicle and add unbelievable shine and gloss to your finish. Since ceramics have been introduced to the market, consumers and manufacturers alike have had to jump onboard and introduce the chemistry of ceramics into their product lines. Here at Adam’s Polishes, we wanted an easier way to provide our customers our newly improved ceramic paint, wheel, and trim coating options into a sprayable application. Using the most unique and user friendly chemistry on the planet, weekend hobbyists and detailing enthusiasts can add ceramic protection to the their finish, wheels, plastic components, trim, and glass in minutes.
    [​IMG]
    Let’s set something straight… In the car care industry, ceramic coatings and “nano” technology have become buzz words and industry standards and although sometimes effective, these are not true “ceramic” coatings. Having silica resins, or “containing SiO2” doesn’t make it a true ceramic coating. Containing ceramic technology is the minimum to passing the first audition in modern car care, but is it an actual ceramic coating? Unfortunately, no. Consider our Ceramic Boost or Ceramic Paste Wax: Both contain heavy amounts of SiO2, give extreme amounts of gloss and protection, and are extremely hydrophobic, but not actual coatings! They are designed for ceramic maintenance in between washes, or an alternative to conventional carnauba/polymer waxes. With Adam’s Ceramic Spray Coating, the proof is in the application— The first swipe of the product will reveal a quickly appearing “rainbow” effect, theres your proof! This is not a streak, smear, or defect— The rainbow effect is a mixture of gases and liquids evaporating and curing to your finish to provide the hydrophobic, acid-resistant, water spot-resistant, and UV inhibiting layer that we’re all after. As the rainbow effect begins to widen and develop, the applied product is turning to evenly hardened SiO2, or glass— hence “glass” coatings. Now, this chemistry is unique to the sprayable coating versus our current coatings as it has a longer working time, allowing it to tack up not as quickly and let you cover an entire hood, as opposed to small sections or proportions.
    What makes a ceramic coating, a ceramic coating?
    Hang tight, we’re going to get scientific with you— Ceramic coatings start with silica resins, ones that are usually cured in a furnace or extreme heat, but are modified versions to cure at room temperature (ie your garage or detail shop!).
    [​IMG]
    The ceramics we’re used to are the modified versions and are neatly ordered and paired molecules of Si and O that make a tetrehedron, which produces a perfect triangle contributing to its stability and strength on your paint. The Si and O molecules are so strong in fact that their bonds don’t step out unless abrasion and/or heat are introduced, hence why Ceramic Coatings only come off with time or accelerated polishing!
    [​IMG][​IMG]
    When developing this product, we wanted to make sure this product could be used in any situation or climate. Both high humidity areas, and dry areas like our headquarters in Colorado were prominent areas of testing grounds and application, and produced exceptional results on all accords.
    “6-8 months? How come it doesn’t last as long as your current paint coating?” So with this new chemistry, we made it pretty easy for application… almost a little too easy! With ceramic coatings, you have a hardness that the ceramic cures to, the hardest measured test being 9H to truly be accredited by the SGS (until they find a 10H hardness pencil at least!). The hardness doesn’t mean how it long it lasts though, but the easiest way to think of this is like a stack of paper towels vs one single sheet. Paper towel doesn’t become stronger or tear-proof as you stack it, maybe a bit more absorbent, but the strength doesn’t change. With Ceramics, particularly our paint and wheel coatings, both are 9H but create different film thickness layers (how many stacks of paper towels high). Paint creates a relatively thin layer, conserving the gloss, shine, and uniqueness of your finish— whereas Wheel creates a thicker layer for heat resistant, reduced brake dust adhesion, and overall increased longevity. With Adam’s Ceramic Spray Coating, the chemistry is unique for the delivery method creating a thin layer of ceramic protection with each wipe! The ease of use and low-level tackiness go hand in hand.
    [​IMG]
    “Can I layer this product to make it last longer?” Yes, of course, but that doesn’t mean layering this product 10 times will make it 10x longer— any application after 3 rounds will render the product redundant and still provide the same hydrophobic effects.
    “What can I use this on? Can I just spray the whole car with it?” Adam’s Ceramic Spray Coating provides protection to an extreme range of areas on your vehicle. Painted surfaces, Wheels, Glass, Headlights, Plastic trim, Bed liners, Tonneau covers, Canvas tops, Floor mats, Unfinished metal— All are safe to be protected. As much as we want you to spray the entire vehicle at once, we strongly recommend that you go panel by panel to ensure thorough application and as much control of overspray as possible.
    “How do I have to wait for it to cure?” One of the benefits of Ceramic Spray Coating is the ease of use, longer working time, and the expedited curing process. Since this product is dispensed through a sprayer, it starts curing as soon as you start to pull the trigger and the product flows onto the towel! Once it’s applied to the surface intended for treatment, let it rainbow and “flash” for 1-2 minutes, then remove with a premium microfiber towel. After the treatment is applied, you’ll want to keep it safe and element-free for about 3-4 hours.
    “What happens if I forget a spot or end up with a high-spot?” Adam’s Ceramic Spray Coating does have a slight self-leveling agent built into the formula for ease of use, but we know that accidents happen. If you forget a spot and you catch it in time (10-20 minutes after removal) simply reapply to that area and wipe off after 1-2 minutes. Reactivating the product will allow for easier removal. If left on for longer, we recommend Brilliant Glaze and a microfiber applicator, or machine polishing with Correcting Polish to fully remove the imperfection.
    smurfslayer likes this.
  2. smurfslayer
    smurfslayer Be vewwy, vewwy quiet. We’re hunting sasquatch77
    3,836
    2,339
    Awesome! Industrial fallout rated. Any chance it will stand up to nuclear fallout? :)
    AdamsPolishes likes this.
  3. AdamsPolishes
    3,034
    2,218
    Mar 15, 2013
Share This Page
