AC not working
BobbyVA
Northern VA
Anyone had any troubled with this? It's 72 out and it's cooler with the windows down ..truck only has 4,000 miles
Wilson
South Dakota
What do you have it set at? Is it set on auto are your vents open do you have your seat on
GotExhaust.com
Is the compressor making any funny noises? With the AC on, open your hood and listen for the refrigerant flowing through the line set. If it's hissing or overly loud, sometimes that's an indication your system is low on charge. It's no uncommon for vehicles to leave the factory with too little refrigerant. If it did work at one time, there's a good possibility you have a leak in the system. If you're lucky, it's just a bum fill port that's slowly leaking. The dealer can test your refrigerant levels and quickly top it off.
BobbyVA
BobbyVA
Northern VA
I'll go check, thanks for the advice. It would be nice to have an idea before I take it to the dealer.
---------- Post added at 06:27 PM ---------- Previous post was at 06:12 PM ----------
When I first brought the truck home, I noticed a little green fluid on the garage floor...wasn't very much and thought nothing of it
