I got a cluster guage code so I think it can.I believe nGauge can only pull powertrain DTCs. You will need ForScan to pull HVAC Module DTCs.
What was the DTC?I got a cluster guage code so I think it can.
That DTC is stored in the PCM. It means the PCM lost communication with the IPC at one point in time. That DTC is not from the IPC, a module cannot lose communication with itself.
