abs/brake light/hill descent warning lights going off
Discussion in 'Ford Raptor Problems and Questions Forum' started by cubiefan101, May 5, 2014.
  1. cubiefan101
    cubiefan101 Full Access Member
    385
    119
    Oct 21, 2012
    Illinois
    Anybody else had this issue?. Started it up the other day and after a few minutes of driving the dash began to go nuts chiming four times and showing the brake light, abs light and hill decent warning light with it stating to check braking system. Also when throughout these errors it won't allow me to use hill descent or off road mode. Any ideas?
  2. All The Way
    All The Way FRF Addict
    36
    1,874
    1,086
    Sep 18, 2011
    Lockport, NY
    third break light or a wheel speed sensor
  3. Huck
    Huck FRF Addict
    4,081
    1,784
    Aug 26, 2012
    Chicago Sw Burbs
    ^^ what he said. I had it happen with an abs speed sensor go bad. But no abs in the snow is a blast
  4. cubiefan101
    385
    119
    Oct 21, 2012
    Illinois
    Im thinking abs sensor too. If checked the third brake light and put rtv adhesive around the gasket already so it should be good.
  5. Huck
    Huck FRF Addict
    4,081
    1,784
    Aug 26, 2012
    Chicago Sw Burbs
    check the rear sensors, they can be easily damaged.
  6. Raptor Embroidery
    Raptor Embroidery aka <b><font color='darkorange'>Raptor_Al_41</font
    3,961
    1,421
    Jan 23, 2012
    Scottsboro, Alabama
    Once you get it fixed (if it is abs) wrap the abs lines and get abs guards from one of our vendors (Sdhq outlaw etc)
  7. 8WOOD
    8WOOD Full Access Member
    230
    217
    Oct 31, 2014
    Don't want to make a new thread so I thought I'd revive this one.
    I just had a rock flip up and cut my ABS wire in half on the rear. I got all the indications previously explained in the first post. I spliced the wires back together and was wondering if there's a trick to clearing the codes? Unplug the battery? Or do I have to have a OBDII tool?
    If anyone knows it would be great info. Thanks
    ***UPDATE***
    I figured it out. I don't know how, but I started turning the traction control button on and off and it suddenly said advance trac enable and then everything worked again. It must have auto reset or I pushed the traction button enough times to reset the system.
  8. All The Way
    36
    1,874
    1,086
    Sep 18, 2011
    Lockport, NY
    Mine cleared right away. 2010 Scab 6.2
    Its fun to unplug one during the winter time. :busastyle:
    lka likes this.
  9. JBronius
    JBronius Member
    6
    May 30, 2012
    Richmond va
    brake warning light frozen pedal. clears
    driving 70 on pa turnpike. 2011 screw. red brake warning comes on. press brake pedal hard as rock no braking! pressed again, felt pulsations like abs. then pedal clears and pushes. normal braking. warning light stays on. got off turnpike. check all wheels and reservoir. all good no leaks. braking normal. stopped vehicle for an hour. warning light cleared on restart. ford dealer reveals no faults or abnormalities. suspect sticking vacuum assist valve which is backed up by abs. drove 500 miles since. no issues. any body experience??
  10. Yukon Joe
    Yukon Joe FRF Addict
    40
    18,308
    11,563
    Nov 16, 2011
    Oak Island, NC
    Not the same driving experience, but close on low speed.
    Turned out to be the wheel speed sensor. Dealer replaced under warranty. Needed to replace the whole hub.
    @Yukon Joe :baby: :baby:
    Drive your raptor here!!!!
    www.runraptorrun.com
    ( * Y * )
    Post a pic ofyour Raptor here:
    https://r.tapatalk.com/shareLink?ur...&share_tid=49261&share_fid=17668&share_type=t
    Calendar contest August 17
    Vote for a pic here: vvvvvvvvvvvv
    http://www.fordraptorforum.com/showthread.php?p=1010757
Share This Page
