Abrupt fuel mileage drop
Ditchplains1
Trescott, ME
Here's a puzzle that I figured out.....
Recently mounted new **** Cepek Fun Country tires 315's with rubber bead balancing, and had my alignment done CORRECTLY!!!!, as well as changed my brake pads.
Suddenly my mileage plummeted; averaging close to 16 mpg, it dropped to 13.
Brakes NOT dragging. No pulling to either side. Coasts like hot ice skates on ice.
Not burning oil; last oil change 3,000 miles prior to onset of decreased mileage...Mobil 1 synthetic as always and new Bosch filter. Air filter looks clean. No emergency brake drag. No abnormal sounds at idle.
The only difference I can be certain of was a new hum with the new tires...
OK....What was it?
Yes I figured it out, and no it was nothing exotic....
Answer tomorrow......
Eddie
Ditchplains1
Ditchplains1
Trescott, ME
EricM,
Good thought...should have mentioned it in earlier post. All four tires at 50# after installation. I dropped them to 42# and kept them there. Same pressure as previous BFG's.
But no not the answer....
Eddie
brc misfit
nor cal
went with a larger tire, decreasing mileage. or the neighbor kid is siphoning off gas while your sleeping.
Truckzor
I was going to guess that the tires were directional and installed backwards but I don't think the fun country is directional. Hmm...
badm0t0rfinger
Rocket Man
The Beach
Weight bro. I went from BFGs to X3s on beadlocks and went from right around 14.2 to just about 12.5. My commute also changed, but I think that less of a role
Hockster
My 45ft Bluewater Party
Winchester, Va
3 mpg loss is quite high for just a same size tire swap but it could be. I installed BFG KM2's and only lost 1.5mpg's. Switched to the new BFG and went back to where it was.
